.NET
Obtain point coordinates froma dwg file through .net
25 REPLIES 25
Message 1 of 26
666 Views, 25 Replies
Good afternoon.
¿it can be possible to get point coordinates or line coordinates from a dwg file using .net language?.
Im spanish, please, sorry for my poor english.
25 REPLIES 25
Message 21 of 26
http://rapidshare.com/files/175593183/Program.rar
This is my code. It's divided in 4 parts. There are four classes written in C#.
Greetings.
Message 22 of 26
It looks like its also mangled from a newsreader,
because
the Line variable is a vertical bar (illegal). I'm curious as
to
how that was mangled. What as the actual variable
used?
I'm just becoming more and more convinced that
what's
actually going with the discussion group nonsense, is
deliberate, malicious sabotage, with little regards for
how
bad it makes the entire organization look.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
"Paul Richardson" <prichardson<lastpoint> wrote in message
href="news:6093915@discussion.autodesk.com">news:6093915@discussion.autodesk.com
this is still unreadable in the Webreader... I
give.
href="news:6093914@discussion.autodesk.com">news:6093914@discussion.autodesk.com
[code]
using (Transaction tr =
doc.TransactionManager.StartTransaction())
foreach (ObjectId id in ids)
        Entity e =
(Entity)tr.GetObject
        (id, OpenMode.ForRead);
        Line
l = e as Line;
        if (l !=
null)
outPut
(string.Format
("Line startpoint:{0}\n",
l.StartPoint));
continue;
DBPoint p = e as DBPoint;
        if
(p != null)
outPut
(string.Format
("Point position:{0}\n",
p.Position));
continue;
[/code]
href="news:6093912@discussion.autodesk.com">news:6093912@discussion.autodesk.com
Sure - post how you did it so others can
see.
This idea works for me...
{code}
        Entity e =
Line l = e as Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
        if
(p != null)
outPut
(string.Format
p.Position));
continue;
{code}
I
have obtained all I needed. Many thanks to all for replies and help me.
😄 I can post my
code?.
Message 23 of 26
Just bad naming on my part... It's a lower case L.
I do think they changed my lower case Ls to
pipes in earlier code I've posted though. At the
time I thought I was nuts...
because
as to
used?
what's
how
through 2009
give.
[code]
        Entity e =
Line l = e as Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
        if
(p != null)
outPut
(string.Format
p.Position));
continue;
[/code]
see.
{code}
        Entity e =
            (id,
OpenMode.ForRead);
Line l = e as Line;
        if (l
!= null)
outPut
(string.Format
l.StartPoint));
continue;
if (p != null)
outPut
(string.Format
p.Position));
continue;
{code}
I
me. 😄 I can post my
code?.
Message 24 of 26
Tony - care to share how you step through and
check type? Everything I've read says not to
use if (typeof(...)) else if (...). Casting using
'as' seems to be a good solution.
Thanks!
because
as to
used?
what's
how
through 2009
give.
[code]
        Entity e =
Line l = e as Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
        if
(p != null)
outPut
(string.Format
p.Position));
continue;
[/code]
see.
{code}
        Entity e =
            (id,
OpenMode.ForRead);
Line l = e as Line;
        if (l
!= null)
outPut
(string.Format
l.StartPoint));
continue;
if (p != null)
outPut
(string.Format
p.Position));
continue;
{code}
I
me. 😄 I can post my
code?.
Message 25 of 26
typeof( typename ) returns a type, which you can compare
to
another type, but that's something I do only if I want to
know
if the two types are the exact same type.
Usually I don't want to know that. Rather, I want to know
if
a given object is an instance of a given type, or any
derived
type, which is what the 'is' operator does.
If you have two types and want to know if one is derived
from
the other you can use Type.IsAssignableFrom(type), which
is
true if the type you call it on, is the type you pass, or any
base
type.
through 2009
href="news:6094121@discussion.autodesk.com">news:6094121@discussion.autodesk.com
and check type? Everything I've read says not to
Thanks!
because
as to
used?
what's
how
Supporting AutoCAD
2000 through 2009
I give.
[code]
        Entity e =
            (id,
OpenMode.ForRead);
Line l = e as Line;
        if (l
!= null)
outPut
(string.Format
l.StartPoint));
continue;
if (p != null)
outPut
(string.Format
p.Position));
continue;
[/code]
message
see.
{code}
        Entity e =
            (id,
OpenMode.ForRead);
size=2>        Line l = e as
Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
size=2>        DBPoint p = e as
DBPoint;
        if (p !=
null)
outPut
(string.Format
p.Position));
continue;
size=2>
{code}
I
me. 😄 I can post my
code?.
Message 26 of 26
Thank you.
to
know
if
derived
from
is
any base
type.
through 2009
using 'as' seems to be a good solution.
Thanks!
because
curious as to
used?
what's
how
Supporting AutoCAD
2000 through 2009
Webreader... I give.
message
[code]
        Entity e =
            (id,
OpenMode.ForRead);
Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
DBPoint;
        if (p !=
null)
outPut
(string.Format
p.Position));
continue;
size=2>
[/code]
message
can see.
{code}
        Entity e =
            (id,
OpenMode.ForRead);
Line;
        if (l !=
null)
outPut
(string.Format
l.StartPoint));
continue;
DBPoint;
        if (p !=
null)
outPut
(string.Format
p.Position));
continue;
size=2>
{code}
I
help me. 😄 I can post my
code?.
”Boost
