.NET
Obtain Northing/Easting
3 REPLIES 3
cschildmeier
796 Views, 3 Replies
Am I just not looking in the right spot or do I need to do maths to figure it out?  There are common things that are obviously easy to grab out of Autodesk.AutoCAD.DatabaseServices.Line(length/start point etc) but northing/easting aren't in there.
3 REPLIES 3
rkmcswain
in reply to: cschildmeier
The end points should be in X,Y,Z format.
Y = Northing and X = Easting
R.K. McSwain     | CADpanacea | on twitter
cschildmeier
in reply to: rkmcswain
AcDb.Line.Endpoint.X/Y/Z
Just as simple as I expected it should be.
Thanks!
Hallex
// place some points on screen, set 'pdmode' to 34 (optional)
// then select all points
// not sure about formatting, probably it's need to remove space
// between char and number, so let me know about
      [CommandMethod("lx")]
        public static void PointLabeling()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            TypedValue[] filter = { new TypedValue((int)DxfCode.Start, "POINT") };
            SelectionFilter filterSset = new SelectionFilter(filter);
            PromptSelectionOptions pso = new PromptSelectionOptions();
           // pso.SingleOnly = true;//comment this if you want to label multiple polylines
            pso.MessageForAdding = "Select points to label >> ";
            PromptSelectionResult psr = ed.GetSelection(pso, filterSset);
            if (psr.Status != PromptStatus.OK)
                return;
            PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter text size: ");
            pdo.AllowZero = true;
            pdo.AllowNone = true;
            pdo.UseDefaultValue = true;
            pdo.DefaultValue = db.Textsize;
            PromptDoubleResult res;
            res = ed.GetDouble(pdo);
            if (res.Status != PromptStatus.OK)
                return;
            double theight = res.Value;
            if (theight == 0)
                theight = 0.2;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                try
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    ObjectId[] ids = psr.Value.GetObjectIds();
                    for (int i = 0; i < ids.Length; i++)
                        DBPoint dpt = tr.GetObject(ids[i], OpenMode.ForRead) as DBPoint;
                        Point3d lp = dpt.Position;
                        string strLab= string.Format(" E {0:f3}\n N {1:f3}",lp.X,lp.Y);
                        // create mtext
                        MText mtxt = new MText();
                        mtxt.SetDatabaseDefaults();
                        mtxt.Attachment = AttachmentPoint.MiddleLeft;
                        mtxt.Location = lp;
                        mtxt.TextHeight = theight;
                        mtxt.Width = 0.0;
                        mtxt.Contents = strLab;
                        mtxt.Layer = "0";
                        mtxt.ColorIndex = 5;
                        mtxt.TransformBy(ucs);
                        // add mtext to database and transaction
                        btr.AppendEntity(mtxt);
                        tr.AddNewlyCreatedDBObject(mtxt, true);
                        tr.TransactionManager.QueueForGraphicsFlush();
                    doc.TransactionManager.FlushGraphics();
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format(
                    "Error:\n{0}\nTrace:\n{1}", ex.Message, ex.StackTrace));
 Chris, see if this helps
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
