.NET
ObjectModified event problem
2 REPLIES 2
Amremad
355 Views, 2 Replies
hello every one
this is my code that i have with problem
 public class CADLogs : Autodesk.AutoCAD.Runtime.IExtensionApplication
    public struct OpenedDocuments
       public Autodesk.AutoCAD.DatabaseServices.Database cDocument ;
       public int Duration;
    public Database  curDwg = new  Autodesk.AutoCAD.DatabaseServices.Database();
    public DocumentCollection DwgIO  = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
    public CADLogs()
        //curDwg.ObjectModified += curDwg_ObjectModified;
        DwgIO.DocumentBecameCurrent += DocumentBecameCurrent;
        DwgIO.DocumentCreated += DocumentCreated;
    private void DocumentBecameCurrent(object sender, DocumentCollectionEventArgs e)
        curDwg = e.Document.Database;
    private void curDwg_ObjectModified(object sender, ObjectEventArgs e)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n modified" + curDwg.Filename + ">>" + DateTime.Now.ToString());
    private void DocumentCreated(object sender, DocumentCollectionEventArgs e)
        e.Document.Database.ObjectModified += curDwg_ObjectModified;
    public void Initialize()
        curDwg = Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase;
    public void Terminate()
        //MessageBox.Show("terminate");
curDwg_ObjectModified works with first drawing only ,but when i open new drawing the event doesn't work , and i trying to solve this problem but i can't ..
can someone help me ??
2 REPLIES 2
Amremad
in reply to: Amremad
any help please ?
Amremad
this is the problem : if any person need to see the solve follow this subject
My Code work on 2014 and doens't Work on 2015
”Boost
