.NET
Active Contributor
0 Kudos
Post 1 of 3
ObjectId value vs. Handle
494 Views, 2 Replies
09-29-2006 10:30 AM
In VBA ObjectId and Handle used to have different behaviors, Handle preserved its value when the drawing was closed and reopened later as opposed to ObjectId. In .NET things have changed and there's an ObjectId object that contains a Handle. I've noticed that ObjectId.ToString keeps the same value if I close AutoCAD and reopen a drawing later, but just to avoid any surprises and maybe get some new information: Is ObjectId a better substitution for the old VBA Handle than the new Handle itself? Or is there any reason why I would have (or want) to use Handle if all I need is a number/string to keep an object's identity in a file in order to refer to it at a later time? Thank you.
*Tony Tanzillo
Post 2 of 3
Re: ObjectId value vs. Handle
09-29-2006 12:10 PM in reply to: ahmed.felix
Nothing has changed.
An ObjectId is not permanent - It's essentially a memory address.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5345717@discussion.autodesk.com...
Valued Contributor
1 Kudo
Post 3 of 3
01-16-2007 08:08 AM in reply to: ahmed.felix
How long is it safe to use an object ID? WIthin the transaction? Within the life of the database? Within the AutoCAD session?
Post to the Community
New Post
