.NET
Message 1 of 1
303 Views, 0 Replies
ObjectDBX
hey, i'm just starting to write / convert code from vb6 to vb.net and i'm having some difficulty with ObjectDBX... i've had a look thru this discussion group and found an example, however, it didn't fit in with what i had already... i'm hoping someone can steer me in the right direction
Ok, first off... here is the code for a drawing open in the drawing editor, which seems to work fine:
Public Function Exists(ByVal sName As String) As Boolean
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForRead)
Dim ReturnValue As Boolean
If lt.Has(sName) Then
ReturnValue = True
Else
ReturnValue = False
trans.Commit()
trans.Dispose()
Return ReturnValue
End Function
what i'm after is something that will handle both: drawings that are open in the editor and also via object dbx... so heres my attempt
Public Function Exists(ByVal sName As String, Optional ByVal bUseObjectDBX As Boolean = False, Optional ByVal sDrawingFilePathDBX As String = "") As Boolean
If File.Exists(bUseObjectDBX) = False Then
Else
'check file exists
db.ReadDwgFile(HostApplicationServices.Current.FindFile(sDrawingFilePathDBX, Database.FromAcadDatabase(Application.DocumentManager.MdiActiveDocument), FindFileHint.Default), IO.FileShare.Read, True, "")
ReturnValue = True
Else
ReturnValue = False
trans.Commit()
trans.Dispose()
Return ReturnValue
End Function
the trouble i'm having is withing declaring / setting / assigning the database. Any help would be great
cheers
Mark
0 REPLIES 0
”Boost
