.NET
objectdbx recover dwg
2 REPLIES 2
kbarnettza
403 Views, 2 Replies
Is it possible to RECOVER a DWG via objectdbx?
At the moment I am using open, but many DWG files issue a "needs Recover" nag message on saving from objectdbx.
I have not found out to disable to messge so my next option is to use recover instead of open - if recover is available in objectdbx.
Thanks for reading.
Kevin.
2 REPLIES 2
artc2
in reply to: kbarnettza
Recover is not available in ObjectDBX.  The recover code is in accore.dll which is not a part of ObjectDBX.
artc2
in reply to: artc2
I forgot to mention that if you are working within Acad and you are using version 2015, there is a .NET API to open a dwg in recover mode:
                    DocumentCollection.AppContextRecoverDocument
it's just not part of ObjectDBX.
”Boost
