- Background: I wrote a VBA code to setup new projects. The code creates dummy files that include layout tabs, blocks and xrefs. Inevitably the project changes and adjustments need to be made. I have a file called XX_template_XX.dwg that includes the new layouts that I will use to update the existing file(s).
The believe the solution I am looking for involves using the ObjectDBX utility and goes something like this as I dont have experience using this utility:
Private ReplaceLayouts_Click()
Dim oDBX
Dim newLayout, newBlock
Dim oldLayout, oldBlock
Dim strFileName As String
'open template and copy layouts?
strFileName = "Q:\Project\XX_Template_XX.dwg"
'open strFileName
'copy layouts using ObjectDBX utility
Set oDBX = GetInterfaceObject("ObjectDBX.AxDbDocument.19")
Set newLayout = ThisDrawing.Layouts.Add("New Layout")
Set newBlock = newLayout.Block
ThisDrawing.CopyObjects newBlock, newLayout
'close template
'open file (that has old layouts) and re-place with new layouts
'delete Layouts
'paste Layouts
ThisDrawing.PasteObjects newBlock, newLayout
'close file
End Sub
As you can see I have no idea what i am doing. please help or forward me a link that will help me learn how to run this function.
Thank You!
-K
If you meant to how to use the code in your VBA project, you'd better to post in Visual Basic forum. This forum is for topic of using AutoCAD .NET API, mainly.
Norman Yuan
