.NET
ObjectContextManager Class
4 REPLIES 4
Ertqwa
797 Views, 4 Replies
Hello Forum,
I use the ObjectContextManager class to manage annotation scales.
objObjectContextCollection = objDatabase.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES");
AcDbObjectContextManager:
Exposes the collection of context types supported by the drawing. Each AcDbDatabase exposes an AcDbObjectContextManager which can be used to register, unregister, and enumerate custom context collections.
Unfortunally I can't find much information about this class. Can anyone give me some information about what a custom context collection is inside AutoCAD, and what kinds are there? Which strings besides "ACDB_ANNOTATIONSCALES" can be used in GetContextCollection()?
Thank you for your time.
4 REPLIES 4
Hallex
in reply to: Ertqwa
Take a look at this article
http://adndevblog.typepad.com/autocad/2012/05/using-the-net-api-to-add-a-scale-to-a-drawing.html
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Ertqwa
in reply to: Hallex
Thank you for your response, but that was not my question.
fenton.webb
in reply to: Ertqwa
The ObjectContextManager is currently only used for Annotation Scaling. However, it was designed to be a generic context object API, meaning that you can create your own Object Context data that utilizes this same object model.
Fenton Webb
AutoCAD Engineering
Ertqwa
in reply to: fenton.webb
Ah ok, ty.
”Boost
