.NET
Object Selection and Zooming
10 REPLIES 10
Message 1 of 11
801 Views, 10 Replies
Hello All,
I want to select object in the drawing programatically. how can i achieve this. I have got Handle in string format. What i have done is:-
ObjectId = Database.GetObjectId(false,GetHandle(hexhandle),1);
objectId.GetObject(OpenMode.ForRead);
Now I want to select this object and after selecting , i want to zoom this object.
Help Plz.
Thanks,,,
10 REPLIES 10
Message 2 of 11
aslam,
This might get to started. it creates a view name based on the selection set
of text string found on layer name "bldgnos" and zooms to that location as
it finds each item.
Hope this helps
John Coon
Private Sub CommandButton1_Click()
UserForm1.Hide
Dim Entity As AcadEntity
Dim FilterData(0 To 0) As Variant
Dim FilterType(0 To 0) As Integer
Dim SelectionSet As AcadSelectionSet
Dim Text As AcadText
Dim View As AcadView
Dim ViewCenter(0 To 1) As Double
Dim magnification As Double
Dim zcenter(0 To 2) As Double
For Each SelectionSet In ThisDrawing.SelectionSets
If SelectionSet.Name = "BldgNos" Then
SelectionSet.Delete
Exit For
Next SelectionSet
Set SelectionSet = ThisDrawing.SelectionSets.Add("BldgNos")
FilterType(0) = 8
FilterData(0) = "BldgNos"
SelectionSet.Select acSelectionSetAll, , , FilterType, FilterData
' Zoom to each text entity in the selection set and name the view.
For Each Entity In SelectionSet
If TypeOf Entity Is AcadText Then
Set Text = Entity
Set View = ThisDrawing.Views.Add(Text.TextString)
ViewCenter(0) = Text.InsertionPoint(0)
ViewCenter(1) = Text.InsertionPoint(1)
View.Width = 200
View.Height = 200
View.Center = ViewCenter
zcenter(0) = ViewCenter(0): zcenter(1) = ViewCenter(1): zcenter(2) = 0
magnification = 200
ZoomCenter zcenter, magnification
Next Entity
SelectionSet.Delete
ZoomExtents
UserForm1.Show
End Sub
wrote in message news:5274071@discussion.autodesk.com...
Hello All,
object.
Help Plz.
Thanks,,,
Message 3 of 11
Hi Hohn,
Thanks for help.
I have achieved my goal by other means. But i am facing problem in Zoom Level. I am using Utils class to select object and zoomextents functions. It works fine. But the selected obect is getting zoomed to entire screen. I want to control this zoom level. My code snippet is as below. If you have any idea, plz give me.
//It will select object
Autodesk.Autocad.Internal.Utils.SelectObjects(objectId);
//It will Zoom this object
Autodesk.Autocad.Internal.Utils.ZoomObjects(objectId);
Message 4 of 11
[code]
using System ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.Geometry ;
using Autodesk.AutoCAD.ApplicationServices ;
using Autodesk.AutoCAD.EditorInput ;
using Autodesk.AutoCAD.DatabaseServices ;
using Autodesk.AutoCAD.Interop ;
[assembly: CommandClass(typeof(ZoomLibrary.Zoom))]
namespace ZoomLibrary
public class Zoom
static public void ZoomObject(ObjectId id, double zoomFactor)
Database db = HostApplicationServices.WorkingDatabase;
AcadApplication app = (AcadApplication) Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
Extents3d ext;
using (Transaction tr = db.TransactionManager.StartTransaction())
Entity en = (Entity) tr.GetObject(id,OpenMode.ForRead);
ext = en.GeomExtents;
Vector3d v = new Vector3d((ext.MinPoint-ext.MaxPoint).ToArray());
app.ZoomWindow((ext.MinPoint-v*100.0/zoomFactor).ToArray(),
(ext.MaxPoint+v*100.0/zoomFactor).ToArray());
// Define Command "TestZoom"
[CommandMethod("TestZoom")]
static public void TestZoom()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptEntityResult rse = ed.GetEntity("\nSelect Entity: ");
if (rse.Status == PromptStatus.OK)
double zoomFactor = 100.0;
PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter zoom factor (0...100) <100>: ");
pdo.UseDefaultValue = true; pdo.DefaultValue = zoomFactor;
pdo.AllowNegative = false; pdo.AllowZero = false; pdo.AllowNone = false;
PromptDoubleResult rsd = ed.GetDouble(pdo);
if (rsd.Status == PromptStatus.OK) zoomFactor = rsd.Value;
ZoomObject(rse.ObjectId,zoomFactor);
[/code]
Message 5 of 11
Thanks John,
I have implemented your sample code. Its almost working. But sometimes it zooms very low and sometimes very big. Can i control the constant zoom means all entities should be zoomed at 70%, whatever their sizes are?
Message 6 of 11
aslam,
I don't have dot net so I don't know how it would work in that but the
magnification zoom along with the height & width you might be about to set
the units based on the size if the objects you are selecting and update the
magnification value from that.
John Coon
wrote in message news:5300685@discussion.autodesk.com...
Thanks John,
Message 7 of 11
Hi John,
I tested the code and find that for all the entity it is zooming good but for DBText (may be other text too) entity , it is not zooming properly, whats the problem with DBText extents? Have you any idea?
Message 8 of 11
Hi John,
Can you help me about thumbnail. I want to save current drawing thumbnail to the disk. How Can I achieve this?
Message 9 of 11
aslam,
Not usre where I got this sample
John Coon
wrote in message news:5303493@discussion.autodesk.com...
Hi John,
Message 10 of 11
hi john,
The sample you have given is in .DVB format. I haven't got any idea about it. In which application should i open this file to see the source. If you have any .NET equvalent , then it would be better?
Message 11 of 11
Hello John,
Its again related to Zoom. I am using ZoomCenter method, for it i want center point. I have got GeomExtents of the entity. How can i calculate the center point of the entity by using GeomExtents. I also want to know how much magnifier i should suppy in the Second Argument of the ZoomCenter() method.
Thanks...
”Boost
