.NET
object id string from windows form back to autocad object id
6 REPLIES 6
wang890
822 Views, 6 Replies
here's what i am doing:
in windows form, open some drawings, just reading, get the layout object id and list them in list view. then i export the list to excel. then i imported the excel text back into windows form, then i can read the list view and grab the drawings and their layouts accordingly. i am stuck on converting the string object id, such as (-4264276) back to object id object. did some research and people try to play with handles. doesn't apply to what i am doing here. so don't even mention handles to me.
i know that the com library can convert object id to object with a string. as the argument. is there something similar in .net.
see attached picture of the windows form.
thank you
Bob
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
6 REPLIES 6
odoshi
in reply to: wang890
If it is doable in COM, then just add the TLB as a reference.
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
wang890
i am going by handle to objectID now.
so just one thing to confirm. the object id does change everytime you open the drawing right? only handle stays the same. the handle only contains 5 characters/number. no wonder software crashes all the time. it's gonna get repeat. they should just use GUID on objects instead. lol.
Stantec
Correct, Handle = Constant, ObjectId = Not Constant between drawing sessions.
Handle is unique per drawing database. You need to use in within the scope
of the drawing. Nothing wrong not being GUID.
"wang890" wrote in message news:6283216@discussion.autodesk.com...
{quote}
....so don't even mention handles to me.
{quote}
ObjectIds are only valid in the session they were obtained from.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
{quote}
instead. lol.
{quote}
Consider learning some basic aspects of programming.
Handles are hexadecimal representations of numbers, which are more compact
than decimal representations.
”Boost
