.NET
tdunn3
Message 1 of 2 (142 Views)
Object data to Aeccpoints
142 Views, 1 Replies
08-06-2012 04:53 PM
I want to be able to attach object data to a cogopoint, becuase we are having problems with the attribute data disappearing from the point. Here is what I have so far but getting a Autodesk.Gis.Map.MapException error thrown.
oAeccApp = oAcadApp.GetInterfaceObject("AeccXUiLand.AeccApplication.9.0")
oAeccDoc = oAeccApp.ActiveDocument
oAeccDB = oAeccApp.ActiveDocument.Database
Dim oPoints As Autodesk.AECC.Interop.Land.AeccPoints
Dim oPoint As Autodesk.AECC.Interop.Land.AeccPoint
oPoints = oAeccDB.Points
Dim pointLocation As Point3d = Nothing
Dim location(0 To 2) As Double
location(0) = x
location(1) = y
location(2) = z
oPoint = oAeccDoc.Points.Add(CType(location, Object))
oPoint.RawDescription = myPoints(4)
oPoint.Number = pid
Dim id As ObjectId = PointEntity.FromAcadObject(oPoint)
Dim pt As PointEntity = acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False)
Dim odtable As ObjectData.Table = tables(tablename)
' Create and initialize an record
Dim tblRcd As Record = Record.Create()
odtable.InitRecord(tblRcd)
Dim val As MapValue = tblRcd(0) ' String type
val.Assign(myPoints(0).Trim)
For cnt = 1 To myPoints.GetUpperBound(0) - 3
val = tblRcd(cnt)
val.Assign(myPoints(cnt + 3))
Next
val = tblRcd(12)
val.Assign(Path.GetFileName(CSV_FileName))
table.AddRecord(tblRcd, id)  ''Autodesk.Gis.Map.MapException is thrown here
tdunn3
Message 2 of 2 (113 Views)
Re: Object data to Aeccpoints
08-08-2012 06:03 AM in reply to: tdunn3
I solved this by importing the points first and then running through the csv again to apply the object data.
