.NET
Obfuscator and my acad plugin dll app
10 REPLIES 10
Message 1 of 11
jaboone
2273 Views, 10 Replies
Not sure if anyone can help if they don't have this software, but am going to try.  Maybe someone knows.
I use logic NP obfuscator and am trying to compile a dll plugin I am wanting to send on the app portathon, so I need an answer as soon as possible if anyone can share some insight.
Obviously there is some obfuscating in the acad support files, that I guess mine is bucking with.  This is the error message I am getting.  I tried to ignore the acad stuff.
Crypto Obfuscator For .Net v2013 R2 Standard (Licensed To: James Boone,Powersoft Engineering), Build:130904
Running from UI - C:\Program Files (x86)\LogicNP Software\Crypto Obfuscator For .Net 2013 R2\CryptoObfuscator.exe
Obfuscator Project File= A:\_EPS folder\PanSchPro acad\bin\EPSElec.obproj
Output Path= A:\_EPS folder\PanSchPro acad\bin\Obfuscator
Loading assembly 'A:\_EPS folder\PanSchPro acad\bin\EPSElec.dll'
Preparing assembly 'EPSElec'
Error occurred while obfuscation: System.IO.FileNotFoundException - System.IO.FileNotFoundException: Could not resolve: Acdbmgd, Version=19.1.0.0, Culture=neutral, PublicKeyToken=null. Specify the path where this assembly resides using 'Search Directories' in the Crypto Obfuscator's Project Properties Dialog (Ctrl+P).
   at A.cb24b5c995a4b3c86147a8d69d9719630.c321f3c9128e424f37bb880e068efff85(c321a25747e1f498390774b65fb9f89af ) in File203:line 108
   at A.c2224c862d1a97307eaa6744d9fd44052.c321f3c9128e424f37bb880e068efff85(c321a25747e1f498390774b65fb9f89af ) in File215:line 71
   at A.c535ae534c1db2c6fa21d03d4b8fe97f6.c321f3c9128e424f37bb880e068efff85(c20ba0ba68fd6b425e71a765705a50574 ) in File182:line 79
   at A.c20ba0ba68fd6b425e71a765705a50574.c321f3c9128e424f37bb880e068efff85() in File2:line 201
   at A.c1a5e0c07abbeebee260c9294e9ffb443.cb3258476904695ff17ea41cfa007be2a(c20ba0ba68fd6b425e71a765705a50574 ) in File270:line 1143
   at A.c7ef3407ce7699a98d477921a4f307e97.c0216acd28360b854616e69342e43c906(c1a5e0c07abbeebee260c9294e9ffb443 , List`1 , Hashtable , c345a8b484323503b63d6257e9c79f632 ) in File270:line 1009
   at A.c7ef3407ce7699a98d477921a4f307e97.c7c3e4ecccb6e8d96390def8e3e3f5e5a() in File270:line 866
   at A.cfa31229d37496446ccf88f83596adf9d.c06aad533d46c5d74d67d9ee472ea5b01() in File314:line 1258
   at A.cfa31229d37496446ccf88f83596adf9d.ca4838fb9343869ab96585d35476ae1ae(c4c650b0a5c7749985595b3e1ea6e3255 ) in File314:line 2548
Learning as I go
10 REPLIES 10
Message 2 of 11
jaboone
in reply to: jaboone
Resolved, sorry.
Learning as I go
Message 3 of 11
santoshr0114
Can you tell how?
Regards
Santosh
Message 4 of 11
jaboone
in reply to: santoshr0114
You have to own a Obfuscator, but most arn't cheap, in the $2500 range, but I was able to find one, LogicNP, out of India for less than $300.  Tell them James Boone sent you.
The product is relativly easy to work, once you learn all the neances of obfuscation and the terminology.
Learning as I go
Message 5 of 11
santoshr0114
Thank You for the information, But how did u solve the error.
Regards
Santosh
Message 6 of 11
tamilanban
Consider two dependent Projects in your solution .A and B , if A.DLL alone is builded and updated in crypto obfuscator then the the references to B.DLL are not got from the metadata from the obfuscator
..... so consider the whole solution always before obfuscating the solution .
Tags (1)
Message 7 of 11
jaboone
The obfuscator I have compiles both at the same time.  Actually I have to take special efforts to remove any I don't want compiled.
Learning as I go
Message 8 of 11
jaboone
Remove the acad dll's from the solution. Told it not to compile acad dlls.
Learning as I go
Message 9 of 11
BKSpurgeon
Hi folks
I'm sure someone will be going through the same problems in the futre. So perhaps I will write a blog post about it once I have the solution.
Context
I have written a dll. I do not want staff/colleagues running off with it. If they do I don't want to make it easy. I am using CryptoObfuscator to obfuscate the dll.
  1. First I clicked on "add Assemblies". I then added the dll which visual studio produced in the bin/release folder.
  2. Then i clicked on some "obfuscation settings"
  3. Then I clicked on "obfuscate"
and it throws up the following screen - which looks exactly like the error James Boone had above.
Jame's solution:
  • Unlike James Boone, in CryptoObfuscator, I did not reference any Autocad Dlls. But within the DLL which I made, there are references to AcDbMgd etc.
  • Am I doing this right? Any help would be much appreciated.
Here are my crypto settings:
I"m using Autocad 2016. And I have made a .net DLL that degubs perfectly. It just can't seem to obfuscate it. any help would be much appreciated.
kind regards
BK
Message 10 of 11
BKSpurgeon
Here is the error log that Cypto Obfuscator spits out:
Crypto Obfuscator For .Net v2015 Enterprise - EVALUATION VERSION, Build:160118
Running from UI - C:\Program Files (x86)\LogicNP Software\Crypto Obfuscator For .Net 2015\CryptoObfuscator.exe
Obfuscator Project File= C:\Users\Koshy\Documents\CryptoObfuscator_projects\test_BubbleDeckObfuscation.obproj
Output Path= C:\Users\Koshy\Documents\CryptoObfuscator_projects\CryptoObfuscator_Output
Loading assembly 'C:\Users\Koshy\Documents\Visual Studio 2013\Projects\Bubble Deck\Bubble Deck\bin\Release\Bubble Deck.dll'
Detected Assembly Target Framework: Normal
Loaded symbols for 'C:\Users\Koshy\Documents\Visual Studio 2013\Projects\Bubble Deck\Bubble Deck\bin\Release\Bubble Deck.dll'
Merging CryptoLicensing assembly in assembly 'Bubble Deck'
Preparing assembly 'Bubble Deck'
Error occurred while obfuscation: System.IO.FileNotFoundException - System.IO.FileNotFoundException: Could not resolve: Acdbmgd, Version=20.0.0.0, Culture=neutral, PublicKeyToken=null. Specify the path where this assembly resides using 'Search Directories' in the Crypto Obfuscator's Project Properties Dialog (Ctrl+P).
at A.c20ba0ba68fd6b425e71a765705a50574.c321f3c9128e424f37bb880e068efff85() in File2:line 225
at A.c1a5e0c07abbeebee260c9294e9ffb443.cb3258476904695ff17ea41cfa007be2a(c20ba0ba68fd6b425e71a765705a50574 ) in File271:line 1171
at A.c7ef3407ce7699a98d477921a4f307e97.c0216acd28360b854616e69342e43c906(c1a5e0c07abbeebee260c9294e9ffb443 , List`1 , Hashtable , c345a8b484323503b63d6257e9c79f632 ) in File271:line 1037
at A.c7ef3407ce7699a98d477921a4f307e97.c7c3e4ecccb6e8d96390def8e3e3f5e5a() in File271:line 894
at A.cfa31229d37496446ccf88f83596adf9d.c06aad533d46c5d74d67d9ee472ea5b01() in File315:line 1397
at A.cfa31229d37496446ccf88f83596adf9d.ca4838fb9343869ab96585d35476ae1ae(c4c650b0a5c7749985595b3e1ea6e3255 ) in File315:line 2713
Message 11 of 11
Jeff_M
in reply to: BKSpurgeon
BK, I don't use CryptoObfuscator so have no idea where you need to add this setting, but, just as the message implies, you need to provide a location for the AcDbmgd.dll (and any other referenced assemblies you use in your builds. In Dotfuscator we have a setting for "User Defined Assembly Load Path" where I specify paths to the Acad, Map, & C3D *mgd.dll's. Without those paths set I get the same error you do.
Jeff_M, also a frequent Swamper
”Boost
