.NET
Distinguished Contributor
4 Kudos
Post 1 of 10
nwcout
456 Views, 9 Replies
10-06-2013 09:14 PM
I know we can create navis file[.nwc] by using nwcout command but how do we create navis file [.nwc ] programatically.
Thanks & Regards
This needs to be done as follow:
[DllImport("accore.dll", CharSet = CharSet.Unicode,
CallingConvention = CallingConvention.Cdecl,
EntryPoint = "acedCommandS")]
private static extern int acedCommandS(
int type1,
string str1,
int type2,
string str2,
int end);
[CommandMethod("NwcOutNet")]
public void NwcOutNet()
Document doc = Application.DocumentManager.MdiActiveDocument;
object filedia = Application.GetSystemVariable("FILEDIA");
Application.SetSystemVariable("FILEDIA", 0);
acedCommandS(5005, "_NWCOUT", 5005, "c:\\Temp\\test.nwc", 5000);
Application.SetSystemVariable("FILEDIA", filedia);
ADN Support Specialist
80 Kudos
Post 2 of 10
Re: nwcout
10-08-2013 02:43 AM in reply to: sanjaymann
There is no API to export to .nwc format. You would need to programmatically send the nwcout command using Document.SendStringToExecute for example.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
4 Kudos
Post 3 of 10
Re: nwcout
10-08-2013 02:57 AM in reply to: philippe.leefsma
Ok. Got the point.I have used Document.SendStringToExecute with attsync :
Dim blname as String="Test"
Dim command As String = "_ATTSYNC Name " + blname + vbCr
doc.SendStringToExecute(command, True, False, False)
But I am unable to call NWCOUT I tried:
Dim path as String="c:\Test"
Dim command As String = "_NWCOUT Path " + path+ vbCr
80 Kudos
Post 4 of 10
Re: nwcout
10-08-2013 03:05 AM in reply to: sanjaymann
Which version of AutoCAD are you using? Because in plain AutoCAD I can't see a NWCOUT command...
Philippe Leefsma
4 Kudos
Post 5 of 10
Re: nwcout
10-08-2013 03:15 AM in reply to: philippe.leefsma
Autocad 2013
4 Kudos
Post 6 of 10
Re: nwcout
10-08-2013 03:24 AM in reply to: philippe.leefsma
The following code prompts me for the path:
Dim dbt AsDatabase = Application.DocumentManager.MdiActiveDocument.Database
Dim doc2 AsDocument = Application.DocumentManager.MdiActiveDocument
Dim command AsString = "_NWCOUT " + "d:\w.nwc" + vbCr
 doc2.SendStringToExecute(command,True, False, False)
How do I manage to pass the file path to the command
80 Kudos
Post 7 of 10
Re: nwcout
10-08-2013 04:10 AM in reply to: sanjaymann
    int type1,
    string str1,
    int type2,
    string str2,
    int end);
Philippe Leefsma
4 Kudos
Post 8 of 10
Re: nwcout
10-09-2013 01:22 AM in reply to: philippe.leefsma
Thanks. This worked like a charm:smileyhappy:
New Member
0 Kudos
Post 9 of 10
Re: nwcout
09-23-2014 06:53 PM in reply to: philippe.leefsma
Hi, Philippe. It was really helpful.
It works fine with AutoCAD 2015, but I need to use this command for AutoCAD 2011.
How can I change values for AutoCAD 2011?
80 Kudos
Post 10 of 10
Re: nwcout
09-24-2014 12:57 AM in reply to: cornking84
For 2011 use acedCommand instead and it is exported directly by acad.exe I believe.
Try the following:
[DllImport("acad.exe", CharSet = CharSet.Unicode,
    EntryPoint = "acedCommand")]
private static extern int acedCommand(
    int type1,
    string str1,
    int type2,
    string str2,
    int end);
Philippe.
Philippe Leefsma
