Hi, i am totaly new with Event in VB.net.
So : my project :
One class with a lot of collection.
I have a MDIFORM for show all stuff inside this class.
so in the class if i add a new object in a collection (ex : block) if want to raise a event .
The Child Form receive this event and adjust the data.
So for this my code :
Inside my class :
'------------------------------------------------------------------------- '------ Ajout d'un Bloc -------------------------------------------------- '------------------------------------------------------------------------- ' ENTREE ' DefBloc : La référence du bloc à traiter (ObjectId) ' SORTIE ' Le pointeur du nouveau Bloc '------------------------------------------------------------------------- Public Function AddBloc(ByRef DefBloc As Object, ByVal Debug As Boolean) As ClassDef0f_Bloc Dim DefRetour As ClassDef0f_Bloc DefRetour = New ClassDef0f_Bloc(DefBloc(GestionAUTOCAD.Enum_GA_GSFB.Nom)) If DefRetour.ExtractionAtt(DefBloc, Debug) = True Then Try 'ajout à la collection DefRetour.ClassBase = Me cCollBloc.Add(DefRetour, DefRetour.Nom) 'MaJ des FenetreConfig RaiseEvent EventBlocNew(DefRetour.Nom) Return DefRetour Catch ex As Exception 'erreur car déjà existant DefRetour.Dispose() DefRetour = Nothing MsgBox("Ce nom de bloc existe déjà !", MsgBoxStyle.Information, "Erreur Utilisateur") Return Nothing End Try Else 'erreur à la création DefRetour.Dispose() DefRetour = Nothing MsgBox("Erreur à l'extraction des attributs", MsgBoxStyle.Information, "Erreur Systeème") Return Nothing End If End Function
--> i raise the évent EventBlocNew
this event is : Shared Event EventBlocNew(ByVal Nom As String) in this class
So in my form :
in the new : AddHandler ClassDef0_StyleGeneral.EventBoiteOpNew, AddressOf EventBoiteOpNew
in the finalize : RemoveHandler ClassDef0_StyleGeneral.EventBoiteOpNew, AddressOf EventBoiteOpNew
i retrieve the event :
Protected Sub EventBlocNew(ByVal Nom As String)
Dim columnB As Windows.Forms.DataGridViewComboBoxColumn = Nothing
columnB= DataGridViewCalque.Columns(EnumCalque.Bloc)
columnB.Items.Remove(Nom)
End Sub
so all my code woks fine in the fist loaded project (in autocad) but when i quit and launch this the code in Protected Sub EventBlocNew(ByVal Nom As String) crash..
--> Windows.Forms.DataGridViewComboBoxColumn --> 0 items...
WHY !
i have tested the sub with a object reference of my MDIForm . (by ref F as object,) -> so i check the num of columns and i have not 0 so with the event i am not in the actual MDIChild Form ?
I dont understand this..
I suggest placing a breakpoint in the constructor and running it twice to simulate that condition.
If another instance is getting created for some reason, breakpoint in the form constructor should get hit and then you can find out from where it is getting called using the call stack.
Hope this helps.
If you can provide a minimal sample project demonstrating the behavior, I can have a look at it.
thx. i do that.
I dont know why with the event i dont have th correct value of my Datagridview..
But i you can share your example for event. i appreciate.
thx
I find my little bug.
i have add the removehandler in my finalyse of the form but this sub is never call.
so i move it to the sub in .designer of the form see below
<System.Diagnostics.DebuggerNonUserCode()> _ Protected Overrides Sub Dispose(ByVal disposing As Boolean) Try If disposing AndAlso components IsNot Nothing Then RemoveHandler ClassDef0_StyleGeneral.EventBoiteOpMaJ, AddressOf EventBoiteOpMaJ DefBlocEnCours = Nothing DefConfigEnCours = Nothing components.Dispose() End If Finally MyBase.Dispose(disposing) End Try End Sub
so the question how i can override this sub in my form ? i can move the sub in my form ? I cant override it.
How i can force autocad to pass in it ? i use form.dispose so if i use it, finalize is never call.
Glad you have found the issue.
How about using the FormClosing or FormClosed event to remove the handler ?
i cant do that.
it is a MDI Chid so i close the form but i reopen after... or i have to add handle in open event.
yes.. i cant do that.
