.NET
Valued Contributor
1 Kudo
Post 1 of 3
Non-Uniformly scaled block
460 Views, 2 Replies
06-15-2011 01:04 AM
Hi all,
In one of my application i do exploding some blocks.
Now i got some non-uniformly scaled blocks from user.
Inside the block there is no 3dsolid or unexplodable objects.
Always it has different scale on Z scale only.(for example x=0.5,y=0.5,z=1.0)
Is there is any method to explode this block?
Otherwise to reset the z scale factor?
Please share.
Thanks & Regards,
G
Cant you just set the scale factors to be the same as x or y?
bref.ScaleFactors = new Scale3d(bref.ScaleFactors.X,bref.ScaleFactors.X,bref.ScaleFactors.X);
Active Contributor
0 Kudos
Post 2 of 3
Re: Non-Uniformly scaled block
06-15-2011 01:45 AM in reply to: ProfWolfMan
10 Kudos
Post 3 of 3
06-15-2011 11:48 AM in reply to: ProfWolfMan
Do you have elevated lines/text/etc inside the block?  Is the block at a different elevation then the linework inside it?  What are you planning on doing with the block?
If the z scale doesn't factor in, then yeah just leave it at 1 or do what the previous poster said and change it to match the x or y component.
-Mark
