.NET
Next available block in sequence
6 REPLIES 6
215 Views, 6 Replies
Does someone have a sample of, or can point in the right direction for searching through blocks in the current file to determine the most recent one.
For example. The current document has blocks called Base1, Base2, Base3, Wall1, Wall2, Wall3 and I want to find out what the last Base# is so that I can create the next in the sequence?
VB code would great but I could probably pick through C# as well. Thanks.
6 REPLIES 6
McSwiller
Using a snippet like this:
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = sourceDb.TransactionManager
Dim blT As Transaction = tm.StartTransaction
Dim dbt As BlockTable = CType(blT.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, True), BlockTable) 'destination block table (this current drawing's block table) Dim btr As BlockTableRecord
Try
Dim boId As ObjectId 'block record Id holder
boId = dbt(blkTblRecName) 'this is where you grab a block table record id by name....
Dim btr As BlockTableRecord = CType(tm.GetObject(boId, OpenMode.ForRead, False), BlockTableRecord)
btr.Dispose()
dbt.Dispose()
' No need to commit
blT.Dispose()
tm.Dispose()
Catch ex As Exception
End Try
-You can find a block table record id by name; looping though incrementally, and not finding one by its name could be caught in the Catch area of the Try block - at least then you'd have the current number to use next.
Cheers.
try this idea.
wrote in message news:5437283@discussion.autodesk.com...
one.
Not need to have opened the block for write, I should have
just opened for read.
"Paul Richardson" wrote in message
news:5437646@discussion.autodesk.com...
try this idea.
one.
well. Thanks.
public static class MyClass
public static string GetBlockName( ObjectId tableId, string prefix )
ArrayList names = new ArrayList();
using( Transaction tr = tableId.Database.TransactionManager.StartTransaction() )
SymbolTable table = (SymbolTable) tr.GetObject( TableId, OpenMode.ForRead );
foreach(ObjectId id in table)
if( ! id.IsErased )
SymbolTableRecord rec = (SymbolTableRecord) tr.GetObject( id, OpenMode.ForRead );
if( rec.Name.StartsWith( prefix, StringComparison.InvariantCultureIgnoreCase ) )
names.Add( rec.Name );
names.Sort();
int n = 0;
while( names.BinarySearch( string.Format( "{0}{1}", prefix, n)) > -1 )
++n;
return string.Format( "{0}{1}", prefix, n );
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
BTW, the name I gave to that method ("GetBlockName"), is
a bit misleading, as it works for any kind of symbol table.
Nice... Thanks.
"Tony Tanzillo" wrote in message
news:5437715@discussion.autodesk.com...
”Boost
