.NET
Newline problem in MText ?
4 REPLIES 4
Jyh2003
2432 Views, 4 Replies
i.e.
myText.Contents = "First line \\P Second line";
I want to get all MText values such as "First line Second line" ;
However, my codes get the value has newline;
"First line
Second line"
        public string GetAllMText()
            string test = string.Empty;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] filter = { new TypedValue(0, "MTEXT"), new TypedValue(8, "0") };
            PromptSelectionResult psr = ed.SelectAll(new SelectionFilter(filter));
            if (psr.Status == PromptStatus.OK)
                List<string> values = new List<string>();
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    foreach (ObjectId id in psr.Value.GetObjectIds())
                        MText text = (MText)tr.GetObject(id, OpenMode.ForRead);
                        values.Add(text.Text.ToString());
                    tr.Commit();
                foreach (string eachString in values)
                    test += eachString;
            return test;
Might I have your kind help, your help would be greatly appreciated.
4 REPLIES 4
CADbloke
in reply to: Jyh2003
You want the .Contents of the MText. Instead of
values.Add(text.Text.ToString();
use
values.Add(text.Contents);
It is already a string to the ToString() call is redundant. Download the SDK for the version you are using and peruse the arxmgd.chm guide, search for MText Properties.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
Jyh2003
in reply to: CADbloke
No, I want to get the value is "First line Second line", not "First line \\P Second line"
if use
 get the value is "First line \\P Second line"
CADbloke
You're right - sorry, I had .Text & .Contents mixed up.
You can replace the carriage return with a space (if you need the extra space). See http://stackoverflow.com/a/238020/492
values.Add(text.Text.Replace(System.Environment.NewLine, " "));
Aaaah, wait, I'm close (I'll leave that here in case it's useful to someone but it's wrong for this exercise), you want
values.Add(text.Text.Replace(@"\\P", " "));
Here is a list of the formatting codes you are likely to come across in MText : http://www.cadforum.cz/cadforum_en/text-formatting-codes-in-mtext-objects-tip8640
I Hope this is more useful than my wrong answer.
CADbloke
I hate this forum software (can't edit my answer). ok, my first line of code will work on MText.Text, the second line of code will work on MText.Contents but you probably already figured that out.
”Boost
