.NET
Newby question
3 REPLIES 3
richie_hodgson
393 Views, 3 Replies
Newby question
I currently have a VBA routine that utilises a dialogue box which has a pull down list box in which I have a list of standard scales, I also have a file search option to look for .csv or .txt files, and the usual quit button, I also have access to sharp develop. what is the process for recreating such a beastie in Sharpdevelop for .net. I also have code which I want to migrate but I think one at a time at this moment.
Richie
3 REPLIES 3
Hallex
in reply to: richie_hodgson
Welcome on board
Here is the quick code
Create Windows Application project
Drop ListBox and 2 Buttons on form
Add this code into the form module
Imports System
Imports System.Text
Imports System.Data
Imports System.IO
Public Class Form1
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim itemarray As ArrayList = New ArrayList()
        Dim myStream As Stream = Nothing
        Dim filedial As New OpenFileDialog()
        filedial.InitialDirectory = "c:\"
        filedial.Filter = "Text files (*.txt)|*.txt|Delimited files (*.csv)|*.csv"
        filedial.Multiselect = False
        filedial.FilterIndex = 1
        filedial.RestoreDirectory = True
        If filedial.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
            Try
                Me.ListBox1.Items.Clear()
                Dim filename As String = filedial.FileName
                itemarray = ReadTxtFile(filename, Me.ListBox1)
            Catch Ex As System.Exception
                MessageBox.Show("Cannot read file from disk. Original error: " & vbCr & Ex.Message)
            End Try
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        Me.Close()
    End Sub
    Public Function ReadTxtFile(ByVal filename As String, ByVal lbox As ListBox) As ArrayList
        Dim rdata As New ArrayList()
        Dim fs As FileStream = Nothing
        Dim txf As StreamReader
        Dim s As String
        Try
            fs = New FileStream(filename, FileMode.Open, FileAccess.Read, FileShare.Read)
            txf = New StreamReader(fs)
            s = txf.ReadLine
            Do Until s Is Nothing
                lbox.Items.Add(s)
                s = txf.ReadLine
            Loop
        Catch ex As System.Exception
            Throw New System.Exception("If the file existed it was closed")
        Finally
            fs.Close()
        End Try
        Return rdata
    End Function
    Private Sub ListBox1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ListBox1.Click
        Dim strscale As String = ListBox1.Text
        MessageBox.Show(strscale)
        ''--> work with selected scale here
    End Sub
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.Text = "ListBox Example"
        Me.Button1.Text = "Select Data File"
        Me.Button2.Text = "Exit Form"
    End Sub
End Class
 Hope this will you get started
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thanks for that, I was in a bit of a hurry yesterday and forgot to add a vital single text  box which asks for a Height for height above datum calculations. Is it too much to ask for you to add this to the form. The next question is where you put
--> work with selected scale here, on my VBA form I used the following
scales.AddItem "5"
scales.AddItem "10" ....
do I do something like
strscale.AddItem "5"
strscale.AddiItem "10"....
Richie
Hallex
Ah, do you want to add custom scales...
It's so easily:
        Dim scalearray() As String = New String() {"1:1", "1:2", "1:5", "1:10", "1:25", "1:50", "1:100"}
        Me.ListBox1.DataSource = scalearray
    End Sub
And also here is a good link I think it would be useful for you too
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
~'J'~
”Boost
