I need some C# sample code about the following features in AutoCAD .NET API:
- Create an custom menu/ribbon in AutoCAD;
- Detect XRefs of an AutoCAD drawing;
- Create/update an drawing legend in AutoCAD
Thanks & Regards,
Rui
Solved by Alexander.Rivilis. Go to Solution.
http://adndevblog.typepad.com/autocad/2012/07/modify-ribbon.html
and CuiSamp sample form ObjectARX SDK 2009
http://adndevblog.typepad.com/autocad/2012/08/analysing-nested-xref-in-drawings.html
What do you mean???
Facebook | Twitter | LinkedIn
@Alexander.Rivilis wrote:>> I need some C# sample code about the following features in AutoCAD .NET API:
What do you mean???
Well, in AutoCAD drawings we can have an legend with some attributes like: File Name, Check Date, Revision, Check Date, Contact Number, Checked By, …
I want set the value of these attributes, and create new attributes.
@FRPT1257 wrote:
Well, in AutoCAD drawings we can have an legend with some attributes like: File Name, Check Date, Revision, Check Date, Contact Number, Checked By, …I want set the value of these attributes, and create new attributes.
http://adndevblog.typepad.com/autocad/2012/05/writing-autocad-drawing-summary-information.html
public void EnumProperties(ref Database db) { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; DatabaseSummaryInfo info = db.SummaryInfo; System.Collections.IDictionaryEnumerator cust = info.CustomProperties; while (cust.MoveNext) { object item = cust.Current; string key = item.key; string value = item.Value; ed.WriteMessage("\nKey={0} Value={1}.", key, value); } }
