.NET
Newbie in AutoCAD .NET API
5 REPLIES 5
FRPT1257
621 Views, 5 Replies
I need some C# sample code about the following features in AutoCAD .NET API:
- Create an custom menu/ribbon in AutoCAD;
- Detect XRefs of an AutoCAD drawing;
- Create/update an drawing legend in AutoCAD
Thanks & Regards,
Rui
5 REPLIES 5
http://adndevblog.typepad.com/autocad/2012/07/modify-ribbon.html
and CuiSamp sample form ObjectARX SDK 2009
http://adndevblog.typepad.com/autocad/2012/08/analysing-nested-xref-in-drawings.html
What do you mean???
Facebook | Twitter | LinkedIn
Expert Elite Member
What do you mean???
Well, in AutoCAD drawings we can have an legend with some attributes like: File Name, Check Date, Revision, Check Date, Contact Number, Checked By, …
I want set the value of these attributes, and create new attributes.
http://adndevblog.typepad.com/autocad/2012/05/writing-autocad-drawing-summary-information.html
Expert Elite Member
How to all attributes (Name/Value)?
public void EnumProperties(ref Database db)
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    DatabaseSummaryInfo info = db.SummaryInfo;
    System.Collections.IDictionaryEnumerator cust = info.CustomProperties;
    while (cust.MoveNext) {
    	object item = cust.Current;
    	string key = item.key;
    	string value = item.Value;
        ed.WriteMessage("\nKey={0} Value={1}.", key, value);
Expert Elite Member
”Boost
