.NET
new line with vbCrLf is not work?
3 REPLIES 3
Amrit.shr
635 Views, 3 Replies
Dear All,
To write for Single line text
in VB6 when we use vbCrLf it work and come in new line  but in .net it is not working
is therre any other way to do same thing.
            Dim Str1 As String = " This is Test for First Line"
            Dim str2 As String = " This is Test for Second Line"
            Dim Str3 As String = Str1 & vbCrLf & str2
            Dim acText As DBText = New DBText()
            acText.SetDatabaseDefaults()
            acText.Position = ed.GetPoint("click Point To Insert").Value
            acText.Height = 1
            acText.TextString = Str3.ToString
            acBlkTblRec.AppendEntity(acText)
            acTrans.AddNewlyCreatedDBObject(acText, True)
 Thanks for help.
3 REPLIES 3
kdub_nz
in reply to: Amrit.shr
I may be wrong, but I didn't think Text used formatting characters.
What does the actual string look like when it's added ??
Regards
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Hallex
You have to use MText istead
~'J'~
Amrit.shr
in reply to: Hallex
thanks
”Boost
