.NET
New class wont load in existing project.
2 REPLIES 2
quigs
456 Views, 2 Replies
Hi there,
When I add a new "class.vb" document in visual studio to an existing project,  and add a command to it, then  netload the project in AutoCAD, it won't recognise the command.  But if I add the command to say an existing class, it works fine.  Any ideas,  Thanks in advance.
Martin.
My name is Martin.. 😄
2 REPLIES 2
in reply to: quigs
Most likely the problem is that your project uses the CommandClass attribute.
If it does, you must use it for every class in your project that has
command methods.
quigs
in reply to: quigs
thanks Tony.  I solvded it 20 mins ago.  If you add new item it wont complie for some reason.  You (well I) have to choose "**** windows form".  No ideza why, but what the hey hey!
Cheers.
Martin.
”Boost
