.NET
New AcadApplicationClass fails
3 REPLIES 3
Tom McHugh
547 Views, 3 Replies
A VB 2003 program, which works just fine when logged in, fails when not logged in. Anyone know why this might be?
The program is designed to create TIF files from (released) AutoCAD files by plotting to a virtual printer on a nightly basis as a scheduled task.
This works just fine by doing a manually RUN of the task.
It fails miserably when trying to run when no one is logged in.
Try/Catch narrows the problem down to the following line of code:
AutocadApp = New AcadApplicationClass
ex.message says "Server execution failed" and nothing more.
Any help may save what hair I have left.
3 REPLIES 3
cgay
in reply to: Tom McHugh
http://discussion.autodesk.com/thread.jspa?messageID=5110379
This might not be exactly the problem you have, but hopefully it can get you started
C
Tom McHugh
Thanks for the response.
Unfortunately the possible solution has a problem (which now has to be researched). But you're right, it's a start.
Thanks again.
Tom McHugh
Finally results, which might be useful to someone else.
Below are some registry keys/values obtained from autodesk support. Note my PC had all values the same EXCEPT ONE. Changing this one value caused Cad Manager Tool to run.
Then, when it ran, it fixed the New AcadApplicationClass instantiation problem.
Below is the fix:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R16.1\ACAD-301:409\CadManagerControl]
"CurVer"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R16.1\ACAD-301:409\CadManagerControl\CommunicationCenter]
"LocalPatchListLocation"=""
"EnableSerialNumberPassing"=dword:00000000
"EnableNonPatchNotifications"=dword:00000001
"EnableCommunicationCenter"=dword:00000001
"DataPollingURL"="http://webservices.autodesk.com/CommCntrLinkCollectionRequest"
"PreviewMode"=dword:00000000
"MaintenancePatchNotificationOption"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R16.1\ACAD-301:409\CadManagerControl\DesignCenter]
"HomePageUrl"="http://webservices.autodesk.com/DesignCenter"
"EnableDesignCenter"=dword:00000001
”Boost
