.NET
netload problem
1 REPLY 1
sudarsann
381 Views, 1 Reply
netload problem
Hi...
I have created a dll to be loaded through "Netload" in Autocad 2011. This dll was created using Visual Studio 2010 (.net framework 4) and it works fine on my system. But when i send that dll to be used on another system which has Autocad Civil 3d 2012 running on it, it shows an eInvalidInput exception at the time 'netload' is used. Can somebody please help?
Regards
Sudarsan
1 REPLY 1
in reply to: sudarsann
Hi Sudarsan,
You have 2 hits going against you - the importantone being that there was a version change from 2011 to 2012. You'll need to download and configure the 2012 SDK to compile against.
The other part is the AutoCAD to Civil platform difference. I can see where it should work as AutoCad is the base for everything else but with Autodesk who knows for sure until you try.
Hope this helps
Tom
”Boost
