.NET
Active Contributor
jithin.dcs
Message 1 of 6 (511 Views)
Netload not loading the dll
511 Views, 5 Replies
11-25-2011 01:46 AM
hi,
i have a set of C# .net dlls (.net 3.5) which i used to load automatically in Autocad 2010. Everything was working perfectly but suddenly one fine day one of the dll stopped loading. So i tried loading it using netload command but doesnt work. Its not showing any messages after netloading and when i type commands of that dll it says unknown command. I tried putting a message box in the initialize of the dll but that message also not showing up.
what could be the problem. please anyone can helpout.
thanks in advance
Jithin Shyam S
Distinguished Contributor
quigs
Message 2 of 6 (507 Views)
Re: Netload not loading the dll
11-25-2011 02:29 AM in reply to: jithin.dcs
with no code it's impossible to give you an answer, but if things suddenly stop
working for me the first thing I do is remove any try catch statements & see
if the error is being caught, if it is it will crash and you can see where.
Or have you added this line of code bellow your "IMPORTS"
<Assembly: CommandClass(GetType(“Class name here”))>
Cheers,
Martin.
My name is Martin.. :smileyvery-happy:
Active Contributor
jithin.dcs
Message 3 of 6 (505 Views)
11-25-2011 02:45 AM in reply to: quigs
thanks for ur reply martin,
actually i think the dll is not at all loading.. because i tried putting initialize method in the class and its not coming inside intialise.. so i think ther is no point in testing by removing try catch block. and can u be more specific on where should i place this code <Assembly: CommandClass(GetType(“Class name here”))>
thanks
Alfred.NESWADBA
Message 4 of 6 (498 Views)
11-25-2011 03:46 AM in reply to: jithin.dcs
this problem could arise if you have the mangaged-dll's copied in your bin-directory.
That works as long as the dll's are the same as AutoCAD has, but e.g. when installing a service pack to AutoCAD that changes the *mgd*.dll you may get this problem.
So look for such files (*mgd*.dll) in your bin-directory, if that are files from AutoCAD remove them (well, backup them before).
For you VisualStudio-project that means you should set the properties of these references to "Copy local" to NO.
- alfred -
Alfred NESWADBA
quigs
Message 5 of 6 (492 Views)
11-25-2011 04:18 AM in reply to: jithin.dcs
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(Namehere))>
Public Class Namehere
    <CommandMethod("CommandName")> _
    Public Sub SunNamehere ()
    End Sub
End Class
dgorsman
Message 6 of 6 (478 Views)
11-25-2011 08:05 AM in reply to: jithin.dcs
Have you loaded any BETA release or newer release software on the computer before your last compile?  I had a similar problem with a routine which required use of COM, a BETA install had overwritten one of the interop DLLs in ...\Common Files\AutoDesk Shared\... resulting in a reference to an interop file version that nobody else had.  Whoopsie...
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
