.NET
Netload not loading the dll
6 REPLIES 6
1913 Views, 6 Replies
hi,
i have a set of C# .net dlls (.net 3.5) which i used to load automatically in Autocad 2010. Everything was working perfectly but suddenly one fine day one of the dll stopped loading. So i tried loading it using netload command but doesnt work. Its not showing any messages after netloading and when i type commands of that dll it says unknown command. I tried putting a message box in the initialize of the dll but that message also not showing up.
what could be the problem. please anyone can helpout.
thanks in advance
Jithin Shyam S
6 REPLIES 6
quigs
with no code it's impossible to give you an answer, but if things suddenly stop
working for me the first thing I do is remove any try catch statements & see
if the error is being caught, if it is it will crash and you can see where.
Or have you added this line of code bellow your "IMPORTS"
<Assembly: CommandClass(GetType(“Class name here”))>
Cheers,
Martin.
My name is Martin.. 😄
in reply to: quigs
thanks for ur reply martin,
actually i think the dll is not at all loading.. because i tried putting initialize method in the class and its not coming inside intialise.. so i think ther is no point in testing by removing try catch block. and can u be more specific on where should i place this code <Assembly: CommandClass(GetType(“Class name here”))>
thanks
Alfred.NESWADBA
this problem could arise if you have the mangaged-dll's copied in your bin-directory.
That works as long as the dll's are the same as AutoCAD has, but e.g. when installing a service pack to AutoCAD that changes the *mgd*.dll you may get this problem.
So look for such files (*mgd*.dll) in your bin-directory, if that are files from AutoCAD remove them (well, backup them before).
For you VisualStudio-project that means you should set the properties of these references to "Copy local" to NO.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
quigs
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(Namehere))>
Public Class Namehere
    <CommandMethod("CommandName")> _
    Public Sub SunNamehere ()
    End Sub
End Class
dgorsman
Have you loaded any BETA release or newer release software on the computer before your last compile?  I had a similar problem with a routine which required use of COM, a BETA install had overwritten one of the interop DLLs in ...\Common Files\AutoDesk Shared\... resulting in a reference to an interop file version that nobody else had.  Whoopsie...
brandel7XT6J
I came across the same issue today... I typed in the "FILEDIA" command and it was on "0" I changed it to "1" and the netload started working...
”Boost
