.NET
Valued Contributor
3 Kudos
Post 1 of 3
netload lsp path issue
124 Views, 2 Replies
06-09-2014 09:47 AM
this LSP code
(defun c:VA00()
 (command "netload" "C:\Acad Auto-KPFF/objectARX_Projects/DLL/vbPaste.dll" "VA00")
 (princ)
 works.
(I have scores of commands that follow this LSP netload format.)
unless I insert a block. (for example from C:\AAA-Stuff).
which in that case I will get the following error on the command line:
The system cannot find the file specified.
File name: 'file:///C:\AAA-Stuff\Acad Auto-KPFFobjectARX_ProjectsDLLvbPaste.dll'
note the difference in the file path.
also, when I first open autocad & I'm in the default drawing1.dwg,
 I'll get the same error with a different path:
File name: 'file:///C:\Users\ssomick\Documents\Acad Auto-KPFFobjectARX_ProjectsDLLvbPaste.dll'
actually, the only time this works, is if I open a drawing from the network. if I subsequently insert a block, or open a drawing from my C: I get similar file not found errors.
anyone know why my path is getting mutilated?
Not sure how that path was working for you before, but try changing it all double backslash. \\
26 Kudos
Post 2 of 3
Re: netload lsp path issue
06-09-2014 12:31 PM in reply to: kcimos
Valued Contributor
3 Kudos
Post 3 of 3
06-09-2014 01:22 PM in reply to: conormccartney3897
interesting.
thanks.
