.NET
Member
qualitysof
Message 1 of 3 (458 Views)
Netload dll failure
458 Views, 2 Replies
02-21-2012 09:52 AM
Hello everyone, first sorry by my english.
I have made a library. NET in a 64-bit PC, but when I load it into another 32-bit PC I get the following message:
Command: netload
Cannot load assembly. Error details: System.BadImageFormatException: Could not load file or assembly 'file:///D:\AppBaseNet2010.dll' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded. File name: 'file:///D:\AppBaseNet2010.dll'    at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)    at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)    at System.Reflection.Assembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, StackCrawlMark& stackMark)    at System.Reflection.Assembly.LoadFrom(String assemblyFile)    at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)    at loadmgd()
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
How I can program this library to accept me in any processor?
Thank you so much!!!
Active Member
ivo.zagar
Message 2 of 3 (442 Views)
Re: Netload dll failure
02-21-2012 12:32 PM in reply to: qualitysof
Build as "ANY CPU".
Also make sure, that you don't copy any unnecessary dependancies (e.g. acdbmgd.dll).
Cheers.
Member
qualitysof
Message 3 of 3 (437 Views)
02-21-2012 12:52 PM in reply to: ivo.zagar
Thank you.
I add to the next line in the acad.exe.config
  <startup useLegacyV2RuntimeActivationPolicy="true">
     <supportedRuntime version="v4.0"/>
  </startup>
I'm development in C#.NET VS2010 Framework 4.0
