If you load your code from a network location, you need to do the .NET CAS
security configuration. Since your new solution is .NET2.0, the security
configuration you have done previously to .NET1.x has no effect to .NET2.0,
therefore, you need to do it to your .NET2.0 code.
Note, .NET2.0 framework does not include the security configuration applet
found in Control Panel->Administrative Tools as .NET1.x, unless you have
.NET2.0 SDK installed. You have to run CASPOL.exe command tool to do the
security configuration, or create a MSI package to deploy the security
settings with domain group policy.
"BillZ" wrote in message news:6007611@discussion.autodesk.com...
VS2005 Express,
Net 2.0 runtime and R2006 Autocad.
I have downloaded VS2005 Express and the distributable version of .net 2.0.
I recompiled some of my code written in net1.1 and VS2003.
Works fine on my computer.
Can I load the net 2.0 runtime on another computer that's been using my old
net1.1 solution.dll and give him the new 2.0 solution.dll and have it work
without having to set new security settings on 2.0?
These are all local installations of AutoCAD but I netload the solution.dll
to the users computer on startup from a network location.
TIA
Bill
