.NET
theEntity
Message 1 of 13 (424 Views)
.NET training labs
424 Views, 12 Replies
08-05-2012 04:19 PM
hey all.  i'll be frequenting regularly this forum from now on. asking all kinds of dumb questions.
like:
who made the these training labs?  http://images.autodesk.com/adsk/files/autocad_net_training0.zip
im having trouble with lab6
an editor.PointMonitor event triggers this sub routine called myPointMonitor
 -the lab then declare a FullSubentityPath variable = e.Context.GetPickedEntities()
 and checks IF (fullEntPath.Length) Then
should their not be an argument here?
i get " out of bound of array " here.   and the IF statement is never executed.
if anyone can assist id appreciate it.
bare in mind i'm new to the autocad api  and have only indermediate exprience with vb.net
edit: sry   the IF is executed  but encounters the exception @
Dim ent As Curve = trans.GetObject(fullEntPath(0).GetObjectIds(0), OpenMode.ForRead)
_gile
Message 2 of 13 (397 Views)
Re : .NET training labs
08-05-2012 11:02 PM in reply to: theEntity
Try to replace Curve with Entity:
Dim ent As Entity = trans.GetObject(fullEntPath(0).GetObjectIds(0), OpenMode.ForRead)
Gilles Chanteau
theEntity
Message 3 of 13 (389 Views)
08-06-2012 12:15 AM in reply to: _gile
it seems that was not the intention because further
 Dim pnt As Point3d = ent.GetPointAtDist(myTypedVal.Value)
GetPointAtDist is not a member of entity
open lab6 and run debug.. check it out , its a small download
_gile
Message 4 of 13 (387 Views)
08-06-2012 12:34 AM in reply to: theEntity
If (fullEntPath.Length) Then
This won't work with C# or (I think) VB with Option Strict On.
Try:
If (fullEntPath.Length > 0) Then
Gilles Chanteau
theEntity
Message 5 of 13 (379 Views)
08-06-2012 01:03 AM in reply to: _gile
was the 1st thing i tried before i came to this forum.
the if statement does run tho.
_gile
Message 6 of 13 (361 Views)
08-06-2012 09:52 AM in reply to: theEntity
Ok, I downloaded the lab and looked up into the code.
I do not know if it's your problem but an exception will occur with the "newInput" command if the cursor comes near an entity which is not a curve.
The "MyInputMonitor" code would check if the entity is a curve. Here's a way (not certain about the VB syntax):
replace:
' open the Entity for read, it must be derived from Curve
' ok, so if we are over something - then check to see if it has an extension dictionary If (ent.ExtensionDictionary.IsValid) Then
with
' open the Entity for read, try to cast it as Curve
Dim ent As Curve = TryCast(trans.GetObject(fullEntPath(0).GetObjectIds()(0), OpenMode.ForRead), Curve)
' ok, so if we are over something - then check to see if it is a curve and if it has an extension dictionary
If ent IsNot Nothing AndAlso ent.ExtensionDictionary.IsValid Then
Gilles Chanteau
Board Manager
StephenPreston
Message 7 of 13 (352 Views)
08-06-2012 10:50 AM in reply to: _gile
Oops. That would be a bug. I'll have someone update the labs with the corrected code. Sorry for the inconvenience and thanks for reporting it.
Cheers,
Stephen Preston
Autodesk Developer Network
_gile
Message 8 of 13 (346 Views)
08-06-2012 11:13 AM in reply to: StephenPreston
Hi Stephen,
There's the same 'bug' in the C# code.
PS: IMO, arriving to this step in the training (using event handlers) it can be assumed that the learner should know enough about debugging and type casting to correct this by himself...
Gilles Chanteau
theEntity
Message 9 of 13 (345 Views)
08-06-2012 11:16 AM in reply to: StephenPreston
ooooh..  here is the culprit himself.  :cattongue:
kudoos on making the labs , i find it very useful to fasttrack my learning. the power point is also very helpful.
now that i have your attention i'd like to pick your brains about dictionaries:
Can you give me a simple senario where saving data to dictionaries is useful / like what kind of data?
i reckon i can store any nessary data i need within variable memory in run time.
\\ saving data to entities seems very much like an GIS application. i rekon i can expose the dictionary in an interface to allow users to append data to entities and make autcad behave like gis software
hey thx _gile for taking a look.
theEntity
Message 10 of 13 (343 Views)
08-06-2012 11:18 AM in reply to: theEntity
-gile
the learner is learing at great pace.  forgive his ignorance
btw - the trycast did not correct my problem
