.NET
.Net Toolbar and Menubar how to
11 REPLIES 11
Message 1 of 12
GStevens
1035 Views, 11 Replies
Please help.
Is there anyone out there who is kindly enough to point me the right direction how to create toolbar and menubar using .Net. It doesn't matter the flavor of .Net program (VB .net/C#/C++).
Thank you in advance.
11 REPLIES 11
Message 2 of 12
in reply to: GStevens
Do you want to dock it inside AutoCAD
Message 3 of 12
GStevens
Dear Stuart Nathan,
Yes I want to dock and undock it as normally autocad toolbar does. Thank you for your help in advance.
GS
Message 4 of 12
NathTay
In 2007 there is a new CUI .NET API.
See the attached image.
Regards - Nathan
Message 5 of 12
GStevens
Unfortunately im using 2006. Kindly teach me how to achieve my goal using 2006 and 2205? Thank you in advance.
Message 6 of 12
NathTay
I'm not sure what is available in the .NET API but you can do it using the ActiveX API. Open the VBA editor and have a look in the Object Browser and Help.
Regards - Nathan
Message 7 of 12
demo2005
by that way, you'd better use activeX
Message 8 of 12
I've only recently started looking at AutoCad again.
There used to be an arx file written by Jorge?? in Autodesk which allowed
you to dock your toolbars. - accont.arx.
The date I have is 01/04/2000
It was a little difficult to use as I remember and in the end I gave it up.
My toolbar ended up independant of AutoCAD, but followed it around.
Message 9 of 12
GStevens
I see. Ok Nathan thank you for your help. I appreciate it so much.
Message 10 of 12
GStevens
Nathan,
Thank you for the idea. Anyway im going to support my project in 2007 so I will definitely able to use the new CUI API.
Once again TY.
GS
Message 11 of 12
GStevens
And what kind of ActiveX you are pertaining to? I really appreciate it if you can give me some idea how to implement it. Thank you.
Message 12 of 12
GStevens
Hello guys,
Thank you to all of you for your effort sin responding to my post. At this time the best solution to my problem is to load CUI file using COM.
”Boost
