.NET
Valued Contributor
0 Kudos
Post 21 of 26
Re: NET-RELOAD Utility for Visual Studio - Download Here
01-18-2013 06:43 AM in reply to: mzakiralam
After you download and unzip the DLL try right clicking on the DLL and pulling up the Properties dialog. On the General tab at the bottom you might see "This file came from another computer and might be blocked...". Click the "Unblock" button and try again.
Kevin
Inventor 2013
30 Kudos
Post 22 of 26
01-18-2013 07:03 AM in reply to: KevinMacDonald
Unfortunately, I did not get any option as you mentioned.
4 Kudos
Post 23 of 26
VB.Net Version (VS 2010)
01-18-2013 07:54 AM in reply to: Artvegas
Here´s the VB.Net class. I hope it helps you!
Serafin A. Albiero Jr.
Valued Contributor
0 Kudos
Post 24 of 26
01-18-2013 09:37 AM in reply to: mzakiralam
I do recall having the same problem, but it's been awhile and I don't remember the precise fix. Something that would fix it for sure is downloading the code and building the DLL yourself. Note that the error being thrown is a sandbox error, i.e. .NET thinks it might be a rogue DLL of some sort. So, you have to convince the .NET run time that is not the case. Building it yourself would definitely accomplish that. Kevin
Inventor 2013
30 Kudos
Post 25 of 26
Re: VB.Net Version (VS 2010)
01-23-2013 06:10 AM in reply to: serafin.albiero
Hi serafin.albiero ,
Thanks a lot for your effort. Today I have tried and successfully build the dll which is currently working fine.
Thanks once again.
Zakir
4 Kudos
Post 26 of 26
01-23-2013 08:39 AM in reply to: KevinMacDonald
Good to know buddy!!  Thanks...
