.NET
.net netload run dll from autocad example
7 REPLIES 7
Message 1 of 8
saluki
2641 Views, 7 Replies
Can anyone provide some instructions on how to run a dll from within autocad.
Specifically how do you code the command into vb.net so it can be called from with in autocad once the dll is loaded with netload?
Thanks in advance.
7 REPLIES 7
Message 2 of 8
in reply to: saluki
Your request is a bit vague.
Try putting a bit more effort into describing what it
is you want to do, and you'll find help a bit more
forthcoming.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4995934@discussion.autodesk.com...
Thanks in advance.
Message 3 of 8
in reply to: saluki
are you looking for somthing like this?
_
Public Shared Sub mycommand()
End Sub
dan
Message 4 of 8
in reply to: saluki
wow that didn't come out right : |
CommandMethod("mycommand", CommandFlags.Modal) _
your code
End Sub
Message 5 of 8
saluki
in reply to: saluki
That's what I'm looking for.
I played around with it and couldn't figure out how to integrate this into my app.
Should I add it as a public sub and then add me.show to open the form in autocad when the user types "mycommand" on the command line after loading the dll with netload?
Message 6 of 8
in reply to: saluki
Access modifiers aren't that much important, unless you need the command method itself elsewhere (in your app, not just as an AutoCAD command). Btw. you do NOT show your forms in AutoCAD by Form.Show() method, 'cause it'll most likely crash. Use Application.ShowModalDialog(...) or ShowModelessDialog(...) methods in Autodesk.AutoCad.ApplicationServices namespace..
Janko Jerinic
Message 7 of 8
in reply to: saluki
i guess you're looking for something like this:
create a class called Commands, like this:
Public Class Commands
_
Public Sub HalloCommand()
PromptMessage(vbCrLf + "Hallo Gebruiker!" + vbCrLf)
End Sub
end Class
wkr
Harold van Aarsen
The command doesn't come cerrectly, i wil post a new reply with a document attached Message was edited by: haroldvanaarsen
Message 8 of 8
in reply to: saluki
the document a told before
”Boost
