I've written managed apps that are being used on
AutoCAD 2006, ADT '06 and MAP3D '06, and there
is no problem. Most use only vanilla AutoCAD APIs,
no vertical APIs.
Without knowing something about your code, I
couldn't begin to speculate about what's wrong.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5116443@discussion.autodesk.com...
I'm trying to use an application made under Visual Studio .NET 2003 in Map 3D. I can't load my dll!!!
When I run the command "NETLOAD" an error ocurrs: "FATAL ERROR: Unhandled e0434f4dh Exception at 7c81eb33h". The same DLL runs under AutoCAD 2006, ADT 2006 and ABS 2006.
I can't load .NET applications in Map 3D?
Best Regards,
Filipe Marcelino
