.NET
.Net equivalent to Esc key
3 REPLIES 3
marskar
1506 Views, 3 Replies
Hi all
Rewriting old VBA code in .Net C#. Strugeling with finding a way to send Esc key. Chr(27) worked fine in VBA.
This VBA code is updating the block definition but aborts by Esc key before insertion.
ThisDrawing.SendCommand ("-insert" + vbLf + "STREAM003=C:/CAD/GDIR/Library/STREAM/STREAM003.DWG" + vbLf + "y" + vbLf + Chr(27))
Tried the same using ACADCMD but this results in 'Requires numeric distance or two points.' in the commandline.
ResultBuffer rb = newResultBuffer();
rb.Add(newTypedValue(5005, "-INSERT"));
rb.Add(newTypedValue(5005, BlockString));
rb.Add(newTypedValue(5005, "y"));
rb.Add(newTypedValue(5005, (char)27));
acedCmd(rb.UnmanagedObject);
Any ideas?
3 REPLIES 3
Hallex
in reply to: marskar
Try this one
            ResultBuffer rb = new ResultBuffer();
            rb.Add(new TypedValue((int)LispDataType.Text, "-INSERT"));
            rb.Add(new TypedValue((int)LispDataType.Text, BlockString));
            rb.Add(new TypedValue((int)LispDataType.Text, "y"));
            rb.Add(new TypedValue((int)LispDataType.Text, @"^C"));
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
marskar
in reply to: Hallex
Sorry, didn't work.
Typing ^C in AutoCAD commandline during an command doesn't help either, so I think we're barking up the wrong tree.
marskar
Hi again
Got it working by using
ads_queueexpr("(command \"-insert\" \"" + BlockString + "\" \"y\" ^C)");
Thanks for pointing me at the right tree afterall. Smiley Very Happy
Cheers
Tore
”Boost
