.NET
Sined99
Message 1 of 8 (1,209 Views)
.NET C# Ribbon tab
1209 Views, 7 Replies
05-13-2013 06:09 AM
Hello, I am new in the autodesk customization, I have autocad 2013 and visual studio 2010
I am interested in make a custom ribbon tab, where I can put a button.
I have found some (incomplete) samples to implement a custom ribbon tab, but I dont know how to "insert" my tab into autocad 2013, and how must I load my tab? with a command?  or it can load automatically?
Can someone show me an example?
Thank you very much.
Here's a simple example of adding a new tab, panel, & button. YOu can have it load automatically by utilizing your Intialize event.
using Autodesk.AutoCAD.Runtime;
using Autodesk.Windows;
namespace AutoCADTest
public class Class1
[CommandMethod("testmyRibbon", CommandFlags.Transparent)]
public void Testme()
RibbonControl ribbon = ComponentManager.Ribbon;
if (ribbon != null)
RibbonTab rtab = ribbon.FindTab("TESTME");
if (rtab != null)
ribbon.Tabs.Remove(rtab);
rtab = new RibbonTab();
rtab.Title = "TEST ME";
rtab.Id = "Testing";
//Add the Tab
ribbon.Tabs.Add(rtab);
addContent(rtab);
static void addContent(RibbonTab rtab)
rtab.Panels.Add(AddOnePanel());
static RibbonPanel AddOnePanel()
RibbonButton rb;
RibbonPanelSource rps = new RibbonPanelSource();
rps.Title = "Test One";
RibbonPanel rp = new RibbonPanel();
rp.Source = rps;
//Create a Command Item that the Dialog Launcher can use,
// for this test it is just a place holder.
RibbonButton rci = new RibbonButton();
rci.Name = "TestCommand";
//assign the Command Item to the DialgLauncher which auto-enables
// the little button at the lower right of a Panel
rps.DialogLauncher = rci;
rb = new RibbonButton();
rb.Name = "Test Button";
rb.ShowText = true;
rb.Text = "Test Button";
//Add the Button to the Tab
rps.Items.Add(rb);
return rp;
You not only need to set references to AcWindows.dll and AdWindows.dll coming from AutoCAD, you also need to set reference to PresentationFramework.dll, PresentationCore.dll, System.Xaml.dll and Windows.Base.dll from .NET framework, because acwindows/adwindows.dll depend on them.
Jeff_M
Message 2 of 8 (1,183 Views)
Re: .NET C# Ribbon tab
05-13-2013 07:28 PM in reply to: Sined99
    public class Class1
            if (ribbon != null)
                if (rtab != null)
                //Add the Tab
                addContent(rtab);
            RibbonButton rb;
            rp.Source = rps;
            rb.ShowText = true;
            rps.Items.Add(rb);
            return rp;
Sined99
Message 3 of 8 (1,169 Views)
05-14-2013 12:34 AM in reply to: Sined99
Thank you for the sample!!, but I have a problem, I am working with autocad 2013 and visual studio 2010, I can't find the reference(.dll) for the Ribbon Controls, I have attached a picture of the errors, I dont know if the Ribbon control can be include in autocad 2013...
-Which is the reference for the ribbon controls??
-Autocad 2013 accept the ribbon controls?
Thank you so much!
norman.yuan
Message 4 of 8 (1,157 Views)
05-14-2013 06:24 AM in reply to: Sined99
Sined99
Message 5 of 8 (1,140 Views)
05-14-2013 11:09 PM in reply to: norman.yuan
Thank you for the answer! it works!, thank you very much!
Valued Contributor
Stemdriller
Message 6 of 8 (1,015 Views)
06-12-2013 02:32 AM in reply to: Sined99
Hi
I have managed to fumble my way through the C# code and converted it into vb.net, and indeed have managed to create a custom tab.
I have placed a button within the panel, but can I get my head around how to fire it when clicked. All i need is to get it to show a form when the user clicks the button.
Think it is to do with event handling, which at the moment is a bit of a blurr to say the least.
Could someone point me in the right direction?
Gareth
norman.yuan
Message 7 of 8 (1,002 Views)
06-12-2013 06:47 AM in reply to: Stemdriller
To respond to user action (clicking, in your case) to a RibbonCommandItem (RibbonButton is derived from RibbonCommandItem), you need to have a class that implements System.Windows.Input.ICommand as a command handler, then assign this command handler to the RibbonCommandItem. Something like:
In the code of adding RibbonButton to a RibbonTab,
RibbonButton btn=new RibbonButton()
btn.Text="Click me";
btn...
btn.CommandHandler=new MyRibbonCommandHandler();
btn.CommandParameter="MyCommand";
btn.ToolTip=....
public class MyRibbonCommandHandler : System.Windows.Input.ICommand
    public void Execute(object parameter)
        RibbonCommandItem btn = parameter as RibbonCommandItem
        if (btn!=null)
            //execute an AutoCAD command, or your custom command defined by [CommandMethod]
            Document dwg=Application.DocimentManager.MdiActiveDocument;
            dwg.SendStringToExecute((string)btn.CommandParameter + " ", true, false, true);
HTH.
Valued Contributor
Stemdriller
Message 8 of 8 (977 Views)
06-13-2013 04:25 AM in reply to: norman.yuan
Thanks, i nailed it now.
GW
