.NET
.NET and critical error in autocad 2010
4 REPLIES 4
508 Views, 4 Replies
i have a problem to run my C# .NET programs in autocad 2010. I have dll generate from visual c# express (i used acdbmgd.dll and acmgd.dll from autocad 2008). This work fine in autocad 2008, 2009. But autocad 2010 show this message: "Critical error: Unsupported version of Windows Presentation Foundation" and autocad fall down. Is this because i compile the program with dll from autocad 2008? Thanks for help Edited by: JosefVesely on Oct 29, 2009 9:18 AM
4 REPLIES 4
AutoCAD 2010 managed assembly requires target framework 3.0 or higher. You will have change the same by modifying project properties in Visual Studio 2008. This can work with AutoCAD 2007 through 2010 also.
Cheers,
-Kailas Dhage
You can't run an app that was compiled against the 2008 versions of the
managed assemblies on AutoCAD 2010. While it may appear to work, there are
API changes that would cause AutoCAD to fail if your code 'hits' one of
them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6280189@discussion.autodesk.com...
I don't understand that. Because of that I have installed AutoCAD 2010 on my PC. If I start the mentioned program there, everything works fine. But at work on all PCs with AutoCAD 2010 it fails with mentioned message. Does anyone know what is the problem?
There should be no problem building applications that target AutoCAD 2010,
if you are using the correct managed assemblies from the SDK. What
assemblies are you referencing, and do you have 'CopyLocal' set to false?
wrote in message news:6283385@discussion.autodesk.com...
”Boost
