.NET
[.NET] Align Object with Plane
2 REPLIES 2
AdriDicri
443 Views, 2 Replies
Hello !
For one of our project, we have a very precise scanner that picks 3 points on a material to generate a plane.
(First point is always (0,0,0))
On autocad, I have to align different object with this plane.
I'd like to know if there is a method to directly align object with this plane?
(I can easily have the normal to this plane, and other informations, if needed)
We already try to calculate angles and make a rotation, but it's not very accurate.
Thanks for help !
Best regards,
Adri DiCri
2 REPLIES 2
Not sure if a direct method exists, this is really specific. Anyway, the Matrix3d struct is the base for all those changes, have you looked at Matrix3d.WorldToPlane method? It can be a start point.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hello. Thanks for your answer !
Finally, i've found the command "3DALIGN" that do exactly what I want. It's not "automatic", but our custommer is happy with that.
Thanks again.
Adri Dicri
”Boost
