.NET
.NET
Active Contributor
btmsoftware
Message 1 of 3 (554 Views)
.NET Add-ins and versions compatibility
554 Views, 2 Replies
03-06-2013 06:17 AM
Hi there.
Has anybody any doc/info regarding .NET add-ins compatiblity across the versions of AutoCAD.
Basically, the story is that we're starting to port our VBA stuff into .NET Add-ins
The issue is that we have customers using from AutoCAD 2008 up to 2013
Everything before 2010 will stay VBA but we'd like to replave VBA starting at 2010
So the question is:
If I write an AutoCAD Add-in in 2010, will it work in 2011 and later ? or should westart in 2011.... Or do we need to recompile for every version of AutoCAD ?
A Ny idea/tip/info is welcomed
From my side, I would say that there is no compatibility issues with version 2007 to 2012 in pure. NET (only very few classes have changed with version 2010) provided that the applications do not use later versions features. No recompilation is necessary. Things may be different for applications using the COM API, or P/Invoking some unmanaged methods.
By cons, there is a real break compatibility with version 2013 and applications must be recompiled with rarely a few changes in the codes.
arcticad
Message 2 of 3 (531 Views)
Re: .NET Add-ins and versions compatibility
03-06-2013 07:31 AM in reply to: btmsoftware
AutoCAD breaks Binary compatability every three versions and you will need to recompile your application with the current version.
http://autodesk.blogs.com/between_the_lines/2009/02/autocad-2010-drawing-file-api-format-compatibili...
http://through-the-interface.typepad.com/through_the_interface/2012/03/migrating-net-applications-to...
(defun botsbuildbots() (botsbuildbots))
_gile
Message 3 of 3 (513 Views)
03-06-2013 10:21 AM in reply to: arcticad
Gilles Chanteau
