.NET
.Net 2007: ObjectData and Topology
6 REPLIES 6
marbile
290 Views, 6 Replies
I am porting from 2006 to 2007 with V Studio 2005. I can not found in the ObjectArx 2007 SDK, en the lib and include directories, the files concerning topology (topoadsrx.lib, for example), o object data (adeads.h). They are not coming with 2007? (They come with 2006 ...)
6 REPLIES 6
NathTay
in reply to: marbile
C:\Program Files\Autodesk Map 3D 2007\ManagedMapApi.dll
Regards - Nathan
He's talking about the native C++ API
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5447453@discussion.autodesk.com...
Regards - Nathan
ffattizzi
They can be found in the Map ObjectARX SDK.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=868205
- Frank
marbile
I downloaded the Map ObjectARX SDK and I found the files i need. Thank you. What I don't understand now is what i has download before. I had an ObjectArx 2007 SDK different from the one I download now, from, i believe, the same autodesk page. But anyway, just curious.
ObjectArx2007 SDK is for generic AutoCAD ObjectARX developing, while MAP
ObjectARX SDK only include Autodesk MAP specific API. If you do vanilla Acad
development, ObjectARX2007 SDK is enough, when doing development for one of
the AutoCAD vertical product, such as AcadMap, you need ObjectARX2007 SDK
and the veritcal product specific ObjectARX API, suh as Map ObjectARX SDK.
wrote in message news:5450728@discussion.autodesk.com...
marbile
thanks
”Boost
