.NET
.NET
Active Contributor
2 Kudos
Post 1 of 6
Nested Blocks From Selected Subentity
744 Views, 5 Replies
09-27-2013 08:48 AM
I'm attempting to have the user select mText from a nested block within a block and then copy the nested block to model space out of the block. I'm able to change the mText successfully, but when I attempt to get the nested block it is not in the list of GetContainers() it only contains the block in model space and the model space block. The nested block is missing in the list. I'm using AutoCAD Civil 3D 2013.
Here is the code to select the mText object which works correctly.
Sub GetNestedMtext()
        ' Have the user select an object. Using the prompt provided.
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Dim entopts As New PromptNestedEntityOptions(Environment.NewLine & "Select a mText in block to replace: ")
        entopts.Message = Environment.NewLine & "Select a mText in block to replace: "
        Dim ent As PromptNestedEntityResult = Nothing
        Try
            ent = ed.GetNestedEntity(entopts)
        Catch
            ed.WriteMessage("You did not select a valid entity")
        End Try
        If ent.Status = PromptStatus.OK Then
                CreateDuplicateBlockInModelSpace(ent)
        End If
    End Sub
Here is the code that attempts to get the nested block which is missing the nested block.
    Private Shared Sub CreateDuplicateBlockInModelSpace(ByVal ent As PromptNestedEntityResult)
        Try
            Dim containerObjIds As ObjectId() = ent.GetContainers()
            Dim blkToExtract As BlockReference = DirectCast(containerObjIds(1).GetObject(OpenMode.ForRead), BlockReference)
            Dim blkToPlace As BlockReference = blkToExtract.Clone()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Dim acBlkTbl As BlockTable
                acBlkTbl = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = tr.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                acBlkTblRec.AppendEntity(blkToPlace)
                tr.AddNewlyCreatedDBObject(blkToPlace, True)
                tr.Commit()
            End Using
        Catch ex As System.Exception
        End Try
    End Sub
 Is there another way I can get the parent block object for the nested object?
Try this snippet (it works for me).
C#
[CommandMethod("Test")]
public void Test()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptNestedEntityResult res = ed.GetNestedEntity("\nSelect a nested entity: ");
if (res.Status != PromptStatus.OK)
return;
ObjectId[] ctnIds = res.GetContainers();
if (ctnIds.Length == 0)
return;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockReference br = (BlockReference)tr.GetObject(ctnIds[0], OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
BlockReference clone = (BlockReference)br.Clone();
ObjectId id = btr.AppendEntity(clone);
tr.AddNewlyCreatedDBObject(clone, true);
clone.TransformBy(res.Transform * br.BlockTransform.Inverse());
ed.SetImpliedSelection(new ObjectId[1] { id });
tr.Commit();
F#
[<CommandMethod("Test")>]
let test () =
let doc = Application.DocumentManager.MdiActiveDocument
let db = doc.Database
let ed = doc.Editor
let res = ed.GetNestedEntity("\nSelect a nested entity: ")
if res.Status = PromptStatus.OK then
let ctnIds = res.GetContainers()
if ctnIds.Length > 0 then
use tr = db.TransactionManager.StartTransaction()
let br = tr.GetObject(ctnIds.[0], OpenMode.ForRead) :?> BlockReference
let btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) :?> BlockTableRecord
let clone = br.Clone() :?> BlockReference
let id = btr.AppendEntity(clone)
ed.SetImpliedSelection([| id |])
tr.Commit()
VB
 <CommandMethod("Test")> _
Public Sub Test()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim res As PromptNestedEntityResult = ed.GetNestedEntity("Select a nested entity: ")
If res.Status <> PromptStatus.OK Then
Return
End If
Dim ctnIds() As ObjectId = res.GetContainers()
If ctnIds.Length = 0 Then
Return
End If
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim br As BlockReference = DirectCast(tr.GetObject(ctnIds(0), OpenMode.ForRead), BlockReference)
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim clone As BlockReference = DirectCast(br.Clone(), BlockReference)
Dim id As ObjectId = btr.AppendEntity(clone)
tr.AddNewlyCreatedDBObject(clone, True)
ed.SetImpliedSelection(New ObjectId(0) {id})
tr.Commit()
End Using
End Sub
You can retrieve the nested block the selected entity belongs to using Entity.BlockName and Entity.BlockId properties.
In the attached drawing I have MText inside "Nested" block, which is nested inside topblk. Here is the output of the following code:
Select nested entity:
Container: topblk
Container: *Model_Space
Entity: Autodesk.AutoCAD.DatabaseServices.MText
Block: nested
[CommandMethod("NestEntSelect")]
public void NestEntSelect()
PromptNestedEntityOptions pneo = new PromptNestedEntityOptions(
"\nSelect nested entity:");
PromptNestedEntityResult pner = ed.GetNestedEntity(pneo);
if (pner.Status != PromptStatus.OK)
return;
using (Transaction Tx = doc.TransactionManager.StartTransaction())
//Containers
ObjectId[] containerIds = pner.GetContainers();
foreach (ObjectId id in containerIds)
DBObject container = Tx.GetObject(id, OpenMode.ForRead);
if (container is BlockReference)
BlockReference bref = container as BlockReference;
ed.WriteMessage("\nContainer: " + bref.BlockName);
Entity entity = Tx.GetObject(pner.ObjectId, OpenMode.ForRead)
as Entity;
ed.WriteMessage("\nEntity: " + entity.ToString());
ed.WriteMessage("\nBlock: " + entity.BlockName);
BlockTableRecord btr = Tx.GetObject(entity.BlockId, OpenMode.ForRead)
as BlockTableRecord;
Tx.Commit();
Philippe.
253 Kudos
Post 2 of 6
Re : Nested Blocks From Selected Subentity
09-28-2013 12:52 AM in reply to: christopher
The ObjectId array returned by GetContainers() method is 0 based.
So, if the selected mtext owns to block 'A' which is nested in block 'B' inserted in model space, GetContainers()(0) returns 'A', GetContainers()(1) returns 'B' and GetContainers()(2) returns the model space ObjectId.
In your code, you get the ObjectId at the 1 index (the second item in the array).
Gilles Chanteau
Active Contributor
2 Kudos
Post 3 of 6
09-29-2013 09:40 AM in reply to: _gile
Yes, that is my expectation of how it supposed to work also. Unfortunately when I run the code I only get two objects back in the collection, it's missing the 0 value we are expecting and insteads returns the block the block is inside of and model space. The nested, nested block is missing.
Here is a video showing my experience with it. The block in blue is the nested block with the blue mtext the item the user needs to select. I then want the blue block's ObjectId to copy it from the block into model space so the user can move it and use it elsewhere in the drawing. The red is the block that holds the blue block.
http://screencast.com/t/UJGlQ0OmbOqt
I'd prefer the user only clicks once and not have to fake a click for the user, which if it is a bug that I'll have to do.
Could it be a version related bug?
253 Kudos
Post 4 of 6
09-29-2013 01:15 PM in reply to: christopher
C#
        public void Test()
                return;
                return;
                tr.Commit();
F#
let test () =
    let ed = doc.Editor
            tr.Commit()
VB
        Public Sub Test()
                Return
            End If
                Return
            End If
                tr.Commit()
            End Using
        End Sub
Gilles Chanteau
ADN Support Specialist
80 Kudos
Post 5 of 6
10-01-2013 01:54 AM in reply to: _gile
Container: topblk
Block: nested
        return;
        //Containers
            as Entity;
        Tx.Commit();
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
51 Kudos
Post 6 of 6
Re: Nested Blocks From Selected Subentity
10-01-2013 09:19 AM in reply to: christopher
Thank you both for the help. Same person, different accounts.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
