.NET
Need to run LISP function synchronously from .NET across multiple drawings
1 REPLY 1
odoshi
1506 Views, 1 Reply
I am using the Application.Invoke() method on 2011+ and am finding it to not work well other than from the command line of a single document.
When I declare a Commandflag.Session flag for my command, and try calling Invoke using more than one parameter on a new drawing where the command was not run from, it bombs out.
So, Drawing1.dwg - Run command
A new Drawing2 is opened, saved, and Invoke called to run some LISP, it will fail.
Does anyone have experience with this?
I did read somewhere that Invoke() may need to be run from a Document context. Does that exclude the Session flag?
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
1 REPLY 1
odoshi
in reply to: odoshi
Forget it 🙂
Using the Interop DLL's and SendCommand will work synchronously if CommandFlag.Session is used.
Doh!
Mike Caruso
”Boost
