Need some help getting started here.
Is the command "exportPDF" and various options available in .NET or VB.Interop?
Goal: To batch print (publish) drawings from our master database so we always have PDF's on hand in our shared drive.
I'm using Autocad 2011 with the included PDF feature.
Solved by michael.robertson. Go to Solution.
Here's a good place to start: http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-multi.html
Cover multisheet plotting. Setting your pc3 file, etc.
Here is a nice plug-in of the month
http://through-the-interface.typepad.com/through_the_interface/plotting/
Mike, a variation of this question: I'm using the FDOT State Kit 2012. All my Page Setups are from the FDOT Master .dwt, with FDOTPostScript.pc3 and the FDOT.stb Plot Style Table. I'm not using Sheet Set Organizer, I just Publish to Plotter from Sheet Set Manager in C3D and convert all the postscripts to .pdf's. When I do this, they plot perfectly and to scale. However, if I try to Publish to PDF or DWFx, I get the origin offset shown in the attached .pdf. Is there a way to fix this?
Pat
