.NET
172 Views, 1 Reply
Need help
Hi all,
I need to "translate" from script code to managed .NET.
In few words, I want to insert into another dwg all acadEntities which don't
have a specific layer(s).
// turning On only the specific layers (CON + CONT)
_LAYER _OFF * _Y
_LAYER _ON CON
_LAYER _ON CONT
_LAYER _SET CONT
// I'm deleting all the entities with Layer = CON/CONT
_ERASE _W -10000.000000,-10000.000000 10000.000000,10000.000000
_LAYER _ON *
_LAYER _S 0
_QTEXTMODE 0
_WBLOCK "My.dwg" _Y 0.000000,0.000000 _W -10000.000000,-10000.000000
Now, in C# I'm enumerating through all AcadEntities and check the Layer
property (foreach AcadEntity in AcadDocument.ModelSpace.Entities ...), BUT
it takes too much.
Maybe you'll point me in the right direction.
Thanks for any advice
1 REPLY 1
Create a SelectionSet with filter set to the layer(s). With
Autodesk.AutoCAD.EditorInput.Editor object, there are quite a few methods:
GetSelection(), SelectAll(), SelectXXXXXX()..... Once you get the entities
into a SelectionSet, you can easily do whatever you want to do to these
entities.
"Bragadiru" wrote in message
news:5375398@discussion.autodesk.com...
Hi all,
_LAYER _OFF * _Y
_LAYER _ON CON
_LAYER _ON CONT
_LAYER _SET CONT
_LAYER _ON *
_LAYER _S 0
_QTEXTMODE 0
it takes too much.
”Boost
