.NET
.NET
1,219 Kudos
Post 11 of 15
Re: Need help with code. I'm new to all this
08-26-2012 10:37 AM in reply to: phives
>> ACAD2010
...and the message from the message above:
>> from assembly 'acdbmgd, Version=18.1.0.0
That shows me that you have referenced the managed dll from AutoCAD 2011, not the one for AutoCAD 2010, don't mix versions! So that is the first problem.
>> BTW. You know that I am doing this from a standalone EXE.
No, should I? Have you told that anywhere in your previous posts?
So Norman (in >>>this post<<<) is absolutely correct with his opinion and when you seek through www to get samples orientate more on VB6 or VBA for AutoCAD (and not dotNET-based application development).
To get the most direct help then is to download the VBA-enabler (from >>>here<<<), if you start then VBAIDE you have the help that shows you how to use COM-based development with AutoCAD.
Good luck, - alfred -
Alfred NESWADBA
0 Kudos
Post 12 of 15
08-26-2012 11:15 AM in reply to: Alfred.NESWADBA
I'm using VisualBasic not VBA.
1,219 Kudos
Post 13 of 15
08-26-2012 11:20 AM in reply to: phives
but the help is the best and the syntax is about the same.
I just wanted to point you to the most easy way to see a lot of sample-code as the VBA-for-AutoCAD shows for nearly every entity-type/every function/property/sub a sample. And as long as you have not installed the VBA-Enabler you won't have access to the help-file (acadauto.chm).
- alfred -
Alfred NESWADBA
0 Kudos
Post 14 of 15
08-26-2012 11:32 AM in reply to: Alfred.NESWADBA
I downloaded the enabler. Have no idea where it installed to. Can't find it on my  machine.
1,219 Kudos
Post 15 of 15
08-26-2012 11:37 AM in reply to: phives
Just downloaded or also the exe started?
If you have started the exe so the VBA-Enabler got installed you can start AutoCAD, start command _VBAIDE and you are in the VBA-environment for AutoCAD.
Alternativly you may search for the file acadauto.chm ==> you can start it and use it for search and for samples for how to access blockreferences, attributereferences, open drawings and so on.
Alfred NESWADBA
