.NET
Need help with code. I'm new to all this
14 REPLIES 14
Message 1 of 15
759 Views, 14 Replies
I'm trying to use this code I founf here in the forum. What I can't figure out is where does it open the drawing and how do I pass it the ObjectID.
PublicSub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname AsString, ByVal AttTag AsString, ByVal AttVal AsString)
Dim MyDb AsDatabase = Application.DocumentManager.MdiActiveDocument.Database
If BlockID.IsNull ThenExit SubTryUsing myTrans AsTransaction= MyDb.TransactionManager.StartTransaction
Dim myBlckRef AsBlockReferenceDim myAttColl AsAttributeCollectionDim myBlckTable AsBlockTableRecord
myBlckRef = BlockID.GetObject(
OpenMode.ForWrite)
If myBlckRef.IsDynamicBlock Then
myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord,
OpenMode.ForRead)
Else
myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord,
OpenMode.ForRead)
EndIfIfString.Compare(myBlckTable.Name, blckname, True) = 0 Then
myAttColl = myBlckRef.AttributeCollection
Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectIdDim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReferenceForEach myEnt InmyAttColl
myAttRef = myEnt.GetObject(
OpenMode.ForWrite)
IfString.Compare(myAttRef.Tag, AttTag, True) = 0 Then
myAttRef.TextString = AttVal.ToString
EndIfNextEndIf
myTrans.Commit()
EndUsingCatch ex AsExceptionEndTryEndSub
14 REPLIES 14
Message 2 of 15
Alfred.NESWADBA
It does not open the drawing, it uses the active document (currently loaded and activated DWG).
Sorry not to understand that. The answer "you call this sub and transfer the objectid by adding it as the first parameter to the calling line-code" will not be what you are looking for, I guess.
- alfred -
PS: to make your code readable within the threads here you should use the icon  in the answering-dialog. Otherwise you see your code gets really unstructured and so useless (spaces and cr missing after pasting your lines).
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 15
in reply to: Alfred.NESWADBA
I want to create a routine that looks like this.
Sub EditAttribute(DWGNAME, BLOCKNAME, ATTRIBUTENAME, ATTRIBUTEVALUE)
The routine will open the specified drawing, find the block and attribute and write a new value in.
Message 4 of 15
Alfred.NESWADBA
and when the block (blockreference) is inserted multiple times in one drawing (e.g. 1 in each layout and 3 in the modelspace)? Which one should then be modified?
- alfred -
Alfred NESWADBA
Message 5 of 15
Each of our blocknames are unique. That's why we do it that way.
Message 6 of 15
Alfred.NESWADBA
find attached the code (and a sample drawing), it's not really tested, so be careful 😉
- alfred -
Alfred NESWADBA
Message 7 of 15
Tx. will try it.....
Message 8 of 15
I'm getting this error.....
Method 'GetEnumerator' in type 'Autodesk.AutoCAD.DatabaseServices.BlockTable' from assembly 'acdbmgd, Version=18.1.0.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
Message 9 of 15
Alfred.NESWADBA
upload your test-drawing and your call-parameters.
But I think it's anything like wrong version of the *mgd*.dll you are referencing ==> what os and what AutoCAD-version (and vertical product) do you work with?
- alfred -
Alfred NESWADBA
Message 10 of 15
fillBlock("C:\Users\PAUL\Desktop\B-03-J-H135.dwg", "RO", "CAB", "UUUU")
ACAD2010. I downloaded the ObjectARX2011. The dll's are there.
BTW. You know that I am doing this from a standalone EXE.
Message 11 of 15
Alfred.NESWADBA
>> ACAD2010
...and the message from the message above:
That shows me that you have referenced the managed dll from AutoCAD 2011, not the one for AutoCAD 2010, don't mix versions! So that is the first problem.
No, should I? Have you told that anywhere in your previous posts?
So Norman (in >>>this post<<<) is absolutely correct with his opinion and when you seek through www to get samples orientate more on VB6 or VBA for AutoCAD (and not dotNET-based application development).
To get the most direct help then is to download the VBA-enabler (from >>>here<<<), if you start then VBAIDE you have the help that shows you how to use COM-based development with AutoCAD.
Good luck, - alfred -
Alfred NESWADBA
Message 12 of 15
I'm using VisualBasic not VBA.
Message 13 of 15
Alfred.NESWADBA
but the help is the best and the syntax is about the same.
I just wanted to point you to the most easy way to see a lot of sample-code as the VBA-for-AutoCAD shows for nearly every entity-type/every function/property/sub a sample. And as long as you have not installed the VBA-Enabler you won't have access to the help-file (acadauto.chm).
- alfred -
Alfred NESWADBA
Message 14 of 15
I downloaded the enabler. Have no idea where it installed to. Can't find it on my  machine.
Message 15 of 15
Alfred.NESWADBA
Just downloaded or also the exe started?
If you have started the exe so the VBA-Enabler got installed you can start AutoCAD, start command _VBAIDE and you are in the VBA-environment for AutoCAD.
Alternativly you may search for the file acadauto.chm ==> you can start it and use it for search and for samples for how to access blockreferences, attributereferences, open drawings and so on.
Alfred NESWADBA
”Boost
