.NET
Name ... Not Declared
3 REPLIES 3
sgrya1
291 Views, 3 Replies
Very new to .NET but can someone help me out with this? I can see that getEndPointOptions shouldn't be dimmed twice but don't know how to fix it. Also getEndPointOptions in bold is "not declared" for some reason.
Can anyone help me?
'Get Start Point
If FirstSpan = True Then
Dim getStartPointOptions As PromptPointOptions = New PromptPointOptions("Locate start point:")
Dim getStartPointResult As PromptPointResult = ed.GetPoint(getStartPointOptions)
If (getStartPointResult.Status = PromptStatus.OK) Then
sp = getStartPointResult.Value
'Get EndPoint
Dim getEndPointOptions As PromptPointOptions = New PromptPointOptions("Locate first high point:")
Else
Dim getEndPointOptions As PromptPointOptions = New PromptPointOptions("Locate next high point:")
Dim getEndPointResult As PromptPointResult = ed.GetPoint(getEndPointOptions)
3 REPLIES 3
sgrya1
in reply to: sgrya1
Sorry, ignore this.
I'm going through tutorials and not used to dimming a variable at the same time as setting it to a value.
Realise now that I can still dim it and then set it later.
chiefbraincloud
in reply to: sgrya1
Just in case, I will mention that another difference between VBA and VB .NET is in the fact that in .NET a variable declared inside a block of code will fall out of scope at the end of that code block. for example, your If statement. anything declared inside the If...End If will not exist after the End If.
sgrya1
in reply to: sgrya1
Thanks for the reply. I got the feeling that was the case when I was shifting lines around. Good to know that that is the reason.
”Boost
