.NET
My Code work on 2014 and doens't Work on 2015
1 REPLY 1
Amremad
320 Views, 1 Reply
hello every one
Why My Code work on 2014 and doens't Work on 2015 ?
using System;
using System.Text;
using Microsoft.VisualBasic;
using System.Windows.Forms;
using System.Timers;
using System.Collections;
using System.Collections.Generic;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.PlottingServices;
namespace CADLogs
    public class CADLogs : Autodesk.AutoCAD.Runtime.IExtensionApplication
    public struct OpenedDocuments
        public Autodesk.AutoCAD.DatabaseServices.Database cDocument ;
        public int Duration;
        public OpenedDocuments(Database doc,int duration)
            cDocument = doc;
            Duration = duration;
    public List<OpenedDocuments> drawings = new List<OpenedDocuments>();
    public Database curDwg = new Autodesk.AutoCAD.DatabaseServices.Database();
    public DocumentCollection DwgIO = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
    System.Timers.Timer  wTimer = new System.Timers.Timer();
    System.Timers.Timer  iTimer = new System.Timers.Timer();
    [CommandMethod("CADLogs")]
    public void CheckMyLevel()
        MessageBox.Show("Hello");
    public CADLogs()
        wTimer = new System.Timers.Timer(2000);
        wTimer.Elapsed  += new ElapsedEventHandler(wTimer_Elapsed);
        wTimer.Disposed += new EventHandler( wTimer_Disposed);
        iTimer.Elapsed += iTimer_Elapsed;
        iTimer.Disposed += iTimer_Disposed;
        //wTimer.Enabled = true;
        DwgIO.DocumentBecameCurrent += DocumentBecameCurrent;
        DwgIO.DocumentCreated += DocumentCreated;
        DwgIO.DocumentDestroyed += DocumentDestroyed;
    private void DocumentBecameCurrent(object sender, DocumentCollectionEventArgs e)
        curDwg = e.Document.Database;
    private void curDwg_ObjectModified(object sender, ObjectEventArgs e)
       Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n modified" + curDwg.Filename + ">>" + DateTime.Now.ToString());
    private void DocumentCreated(object sender, DocumentCollectionEventArgs e)
        if (e.Document.Database != null)
            e.Document.Database.ObjectModified += curDwg_ObjectModified;
            drawings.Add(new OpenedDocuments(curDwg, 0));
        else
            MessageBox.Show("Null");
    private void DocumentDestroyed(object sender, DocumentDestroyedEventArgs e)
        foreach(OpenedDocuments doc in drawings)
            MessageBox.Show(e.FileName);
            //if (doc.cDocument.BlockTableId == )
            //MessageBox.Show(doc.cDocument.BlockTableId.ToString());
    private void iTimer_Disposed(object sender, EventArgs e)
    private void iTimer_Elapsed(object sender, ElapsedEventArgs e)
    private void wTimer_Disposed(object sender, EventArgs e)
    private void wTimer_Elapsed(object sender, ElapsedEventArgs e)
    public void Initialize()
        curDwg = Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase;
        curDwg.ObjectModified += curDwg_ObjectModified;
    public void Terminate()
        //MessageBox.Show("terminate");
1 REPLY 1
khoa.ho
in reply to: Amremad
I've just tested your code work on my AutoCAD 2015, with your attached project. I don't know why it did not work at your end.
”Boost
