.NET
My button commands not work?
3 REPLIES 3
h.sezenn
604 Views, 3 Replies
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Colors
Public Class Container3
    <CommandMethod("CreateAndAssignALayer")> _
    Public Sub CreateAndAssignALayer()
        '' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Layer table for read
            Dim acLyrTbl As LayerTable
            acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                         OpenMode.ForRead)
            Dim sLayerName As String = "Center"
            If acLyrTbl.Has(sLayerName) = False Then
                Dim acLyrTblRec As LayerTableRecord = New LayerTableRecord()
                '' Assign the layer the ACI color 1 and a name
                acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByAci, 1)
                acLyrTblRec.Name = sLayerName
                '' Upgrade the Layer table for write
                acLyrTbl.UpgradeOpen()
                '' Append the new layer to the Layer table and the transaction
                acLyrTbl.Add(acLyrTblRec)
                acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _
                                         OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                            OpenMode.ForWrite)
            '' Create a circle object
            Dim acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 1
            acCirc.Layer = sLayerName
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
            '' Save the changes and dispose of the transaction
            acTrans.Commit()
        End Using
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim cls As Container3
        cls = New Container3()
        cls.CreateAndAssignALayer()
    End Sub
End Class
 I have like this code.
if I use the <CommandMethod("CreateAndAssignALayer")> _
this code. my circle was drawn.as you see at picture1
but when I try to click button1
my code has an error.
also it it detials.
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eLockViolation
   at Autodesk.AutoCAD.DatabaseServices.Transaction.GetObject(ObjectId id, OpenMode mode)
   at menu_container_treeview.Container3.CreateAndAssignALayer() in D:\menu_container_treeview\Container3.vb:line 49
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AdApplicationFrame.DLL
Acdbmgd
    Assembly Version: 18.2.0.0
    Win32 Version: 18.2.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcdbMgd.DLL
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll
AdWindows
    Assembly Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AdWindows.DLL
PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/Acmgd.DLL
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcCui.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcWindows.resources.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcWindows.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
    Assembly Version: 5.8.0.0
    Win32 Version: 5.8.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/ManagedMC3.DLL
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
AcTaskDialogs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcTaskDialogs.DLL
AcTaskDialogs.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcTaskDialogs.resources.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcLayer.resources.DLL
AcButterflyExt
    Assembly Version: 1.0.0.23
    Win32 Version: 1.0.0.23
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcButterflyExt.DLL
AcButterflyExt.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcButterflyExt.resources.DLL
PresentationFramework.Luna
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcMrUI.DLL
AcMrUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcMrUi.resources.DLL
AcMr
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcMr.DLL
System.Runtime.Serialization
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.resources
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_tr_b77a5c561934e089/System.resources.dll
AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/AcDialogToolTips.DLL
AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/en-US/AcDialogToolTips.resources.DLL
UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
huseyin_menu_container_treeview
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///D:/AUTOCAD/HAZIR%20PROGRAMLAR/huseyin_menu_container_treeview/huseyin_menu_container_treeview/bin/Release/huseyin_menu_container_treeview.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 11.0.50709.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
mscorlib.resources
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_tr_b77a5c561934e089/mscorlib.resources.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
line 48 ___Dim acBlkTblRec AsBlockTableRecord
line 49____acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
line 50____OpenMode.ForWrite)
 I want to add my circle with button. but I dont know how I do this?
Help me !
_____________________________________________________________________________________
Everything For Duct
3 REPLIES 3
Alfred.NESWADBA
in reply to: h.sezenn
try to lock the document before you start the transaction (and .Dispose afterwards to free the document or Using ... End Using).
   Using acDocLock As DocumentLock = acDoc.LockDocument
      'do you changes
   End Using
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
h.sezenn
in reply to: Alfred.NESWADBA
Thank you your answer. it is works 🙂
Everything For Duct
Alfred.NESWADBA
You are welcome, glad to know it solved your problem,, - alfred -
Alfred NESWADBA
”Boost
