.NET
Multiple entities jig
2 REPLIES 2
1179 Views, 2 Replies
How to use jig for multiple entities.
Suppose if i want to move more than one entity and want to move those entities visually while mouse move, how to use jig without creating entities as a block?
Thanks in advance.
Srinivas.
2 REPLIES 2
Hi Srinivas,
I do it like this. But I'm just doing these things for fun, therefore the
code is maybe not the best.
[code]#region Using directives
using System;
using System.Collections;
using System.Collections.Generic;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using RSNNAcadApp.ExtendedCommands;
#endregion
[assembly: CommandClass(typeof(RSNNAcadApp.ExtendedCommands.Copy))]
namespace RSNNAcadApp.ExtendedCommands
class Copy
private Matrix3d UcsMatrix;
private Point3d m_basePoint;
private Point3d m_destinationPoint;
private Curve BaseCurve;
private Matrix3d transMat;
private Vector3d xAxisFrom, yAxisFrom, zAxisFrom;
private Vector3d xAxisTo, yAxisTo, zAxisTo;
/// Moves blockreferences along a Curve with a given distance
[CommandMethod("KOPIERENENTLANGMITBASIS", CommandFlags.UsePickSet)]
public void CopyAlongCurve()
Database db = HostApplicationServices.WorkingDatabase;
//Transaction myT = db.TransactionManager.StartTransaction();
Editor ed =
Application.DocumentManager.MdiActiveDocument.Editor;
try
PromptSelectionOptions ssOptions = new
PromptSelectionOptions();
ssOptions.MessageForAdding = "\nObjekte wählen: ";
ssOptions.MessageForRemoval = "\nObjekte entfernen: ";
ssOptions.AllowDuplicates = true;
PromptSelectionResult ssResult = ed.GetSelection(ssOptions);
if (ssResult.Status != PromptStatus.OK)
return;
if (ssResult.Value.Count == 0)
return;
PromptEntityOptions entOptions = new
PromptEntityOptions("\nBezugslinie wählen, entlang der kopiert werden
soll");
entOptions.SetRejectMessage("\nKann entlang dieses Objekts
nicht kopieren. Nur Kurvenobjekte können verwendet werden.");
entOptions.AddAllowedClass(typeof(Curve), false);
PromptEntityResult entResult = ed.GetEntity(entOptions);
if (entResult.Status != PromptStatus.OK)
return;
ObjectId BaseCurveId = entResult.ObjectId;
//Get a base point from the user
PromptPointResult pointResult = ed.GetPoint("\nBasispunkt:
if (pointResult.Status != PromptStatus.OK)
return;
UcsMatrix = ed.CurrentUserCoordinateSystem;
m_basePoint = pointResult.Value.TransformBy(UcsMatrix);
do
using (Transaction myT =
db.TransactionManager.StartTransaction())
BaseCurve = (Curve)myT.GetObject(BaseCurveId,
OpenMode.ForRead);
if (BaseCurve == null)
return;
Point3d tmpbasePoint =
BaseCurve.GetClosestPointTo(m_basePoint, false);
xAxisFrom =
BaseCurve.GetFirstDerivative(tmpbasePoint).GetNormal();
yAxisFrom =
BaseCurve.GetSecondDerivative(tmpbasePoint).GetNormal();
if (yAxisFrom.IsZeroLength() ||
!yAxisFrom.IsPerpendicularTo(xAxisFrom))
if (BaseCurve.IsPlanar)
yAxisFrom =
BaseCurve.GetPlane().Normal.CrossProduct(xAxisFrom.GetNormal()).GetNormal();
else
yAxisFrom =
xAxisFrom.GetPerpendicularVector().GetNormal();
zAxisFrom =
xAxisFrom.CrossProduct(yAxisFrom).GetNormal();
//Initiate the drag callback delegate
DragCallback dragCallbackDelegate =
this.FollowCursor;
//Start the drag operation
PromptDragOptions dragOptions = new
PromptDragOptions(ssResult.Value, "\nZweiter Punkt angeben oder",
dragCallbackDelegate);
string kwDefault = "Beenden";
dragOptions.Keywords.Add(kwDefault);
dragOptions.Keywords.Default = kwDefault;
PromptPointResult destinationPointResult =
ed.Drag(dragOptions);
if (destinationPointResult.Status !=
PromptStatus.OK)
return;
m_destinationPoint =
destinationPointResult.Value.TransformBy(UcsMatrix);
//m_destinationPoint = destinationPointResult.Value;
Point3d tmpdestinationPoint =
BaseCurve.GetClosestPointTo(m_destinationPoint, false);
xAxisTo =
BaseCurve.GetFirstDerivative(tmpdestinationPoint).GetNormal();
yAxisTo =
BaseCurve.GetSecondDerivative(tmpdestinationPoint).GetNormal();
if (yAxisTo.IsZeroLength() ||
!yAxisTo.IsPerpendicularTo(xAxisTo))
yAxisTo =
BaseCurve.GetPlane().Normal.CrossProduct(xAxisTo.GetNormal()).GetNormal();
else
yAxisTo =
xAxisTo.GetPerpendicularVector().GetNormal();
zAxisTo = xAxisTo.CrossProduct(yAxisTo).GetNormal();
//Determine the final displacement matrix
transMat = Matrix3d.AlignCoordinateSystem(
m_basePoint, xAxisFrom, yAxisFrom, zAxisFrom,
m_destinationPoint, xAxisTo, yAxisTo, zAxisTo);
myT.Commit();
//transform the ss to the new location
Utils.MyUtils.TransformClonedSelectionSet(ssResult.Value,
transMat);
} while (true);
finally
//myT.Dispose();
//DragCallback Delegate
public SamplerStatus FollowCursor(Point3d currentPoint, ref Matrix3d
transMat)
Point3d tmpcurrentPoint =
BaseCurve.GetClosestPointTo(currentPoint.TransformBy(UcsMatrix), false);
xAxisTo =
BaseCurve.GetFirstDerivative(tmpcurrentPoint).GetNormal();
yAxisTo =
BaseCurve.GetSecondDerivative(tmpcurrentPoint).GetNormal();
yAxisTo =
else
yAxisTo = xAxisTo.GetPerpendicularVector().GetNormal();
currentPoint.TransformBy(UcsMatrix), xAxisTo, yAxisTo,
zAxisTo);
return SamplerStatus.OK;
}[/code]
schrieb im Newsbeitrag news:5987129@discussion.autodesk.com...
as a block?
Thanks in advance.
Srinivas.
Hi Roland,
Thanks for your reply. This is solved my problem.
Srinivas.
”Boost
